03-29-2005, 10:56 PM | #1 |
1970 K10, 350, 4spd!
Exhaust options/help?
Ok, I have an exhaust leak coming from the passanger side (bottom of the manifold area). I took it apart, the pipe and heater riser/spacer thing-a-magig. However I cant get to the top of the pipe to clean it up. The previous owner welded the exhaust system together so I can dismantle it to clean up that end. I assume it needs a new donut gasket and flange gasket and it would be good to go? However since I can get to the top of it to clean the pipe I dont see this being easily accomplished. I dont see any holes in the pipe or muffler. What should I do?
I looked on summit racing and found this pre fabricated system. I am not even sure this part number will fit a 4x4 since its listed only for a C10? HOK-16621HKR $ 159.88 Local muffler shop says they can do from the manifold back for between $ 180.00 - 220.00. Thats with the aluminized 16 gauge steel 2 1/4" pipe. If I do get a new system what muffler should I go with? This isnt a show truck or even a nice truck so I dont really want to be spending 100 bucks a piece of mufflers. Or should I try to remove the weld and break the pipes apart, clean the top of the pipe and put the new gaskets on it and let it be for awhile? Its a 1970 Chevy K10 |
03-29-2005, 11:28 PM | #2 |
You should be able to get a set of cherrybomb glasspacks from autozone for about $35.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
03-29-2005, 11:59 PM | #3 |
You can get no-name turbo's cheap too. Thats what I got and actually I kinda like the sound. Not too loud, but it rumbles
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree |
03-30-2005, 01:26 AM | #4 |
Still drivin' a Rat Rod
Jegs has some "Value" priced Thrush turbos mufflers under 20 bucks each.They sound pretty good.
Of course me being cheap,and usually financially challenged,I would repair what was there if possible.
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
