03-30-2005, 12:10 AM | #1 |
69's th400 won't shift out of 1st...wtf...
well just put a new intake on it...holley carb,,,, o yea lifters.....
airrade spacer......run's excellent.....just won't go th400 stuck in first gear.....now what? |
03-30-2005, 12:17 AM | #2 |
67-72 Addict!
Is the vacuum for the tranny hooked up to the carb?
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
03-30-2005, 12:19 AM | #3 |
He's got mean nasty FANGS!
Could either be the vac modulator or the governor, thats what i'd check first...
2004 K2500 Burb 1999 C3500 1985 Cutlass Supreme 1969 C-10 1967 C-10 Panel josh@67-72chevytrucks.com |
03-30-2005, 12:21 AM | #4 |
Custer had a plan too.
Once my truck would not shift out of first. I had knocked the vac line loose.
72 K15 GMC (aka Big White) Performance Rockers, Cab Corners, and Floors Fossil Fuel Glutton Neighborhood Nuisance 98 BMW 540i for Speed (Sold ) 05 Subaru Outback for mileage |
03-30-2005, 02:39 AM | #5 |
Will the trans shift through the gears if you run through them manually (L1, L2, D) instead of starting just in Drive?
Truck #1: 1972 Chevrolet K20 Cheyenne Custom Camper SB400, TH400, NP205 Truck #2 1967 Chevrolet C10 Custom Sport Truck 327 small journal, TH400 |
03-30-2005, 09:42 AM | #6 |
Never enough time!!
That would be my guess...vacuum line off at one end or the other, should shift up manually though.
03-30-2005, 12:22 PM | #7 |
Professional Grade
Mine did that too, cept if you really pushed it,then it'd shift. I just knocked the modulator line off enough that it looked like it was on, but it wasn't :P
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
03-30-2005, 05:55 PM | #8 |
its all about the +6 inches
yep, if you shift it manually, and it shifts, then your modulator is either not hooked up...not getting proper vac...or inoperative.
