Old 03-30-2005, 11:00 AM   #1
71super402
upgrading braking?
Has anyone changed out their master cylinder and booster for a more modern version like a 90's corvette unit? Mine is getting worn and leaking and I was thinking of upgrading if it isnt to difficult and if the results are that much better. Thanx!
71super402 is offline   Reply With Quote
Old 03-30-2005, 01:17 PM   #2
avejoe
Custer had a plan too.
avejoe's Avatar
I went to a dual diaphram booster and new master. About $140 and it made a HUGE difference.
72 K15 GMC (aka Big White)
Performance Rockers, Cab Corners, and Floors
Fossil Fuel Glutton
Neighborhood Nuisance
98 BMW 540i for Speed (Sold )
05 Subaru Outback for mileage
avejoe is offline   Reply With Quote
Old 03-30-2005, 01:47 PM   #3
71super402
Was it a direct bolt on? Also, which brand are they or what did they come off of?
Old 03-31-2005, 10:23 AM   #4
71super402
No one elso has done this?
Old 03-31-2005, 10:42 AM   #5
tnblazerk5
User #12137
tnblazerk5's Avatar
i put a 81 master cyd and booster on a 67 truck i also had to make a rod from the master cyd to the booster cause the 67 one was to short besides that it was a bolt up deal !! oh the 81 stuff was metric was a pain in the a$$ to find all the fittings next time i will use 79 and older stuff
tnblazerk5 is offline   Reply With Quote
Old 03-31-2005, 01:17 PM   #6
Low69CST
I bought this unit. Almost direct bolt on. Had to shave the firewall bracket to fit over thestuds and the brake rod was cut to fit. Both front & rear fluid ports take small fittings, so that has to be adapted. Not on the road yet so, i odon't know how well it works. Someone else on the board has one, i got the idea from them. I thought I had a better picture, I will get one sometime.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 03-31-2005, 01:48 PM   #7
70c10
67-72 Addict!
70c10's Avatar
LOW69CST, that looks good!.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
