Old 03-30-2005, 02:04 PM   #1
farside847
farside847's Avatar
CarDefender Killswitch
Found these guys on the net that have a pretty cool looking killswitch
that is proximity activated. Anyone every used one?
http://www.cardefender.com/home
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 03-30-2005, 02:11 PM   #2
boraxman
Keepin an eye out
boraxman's Avatar
Looks neat, but I can do basically the same thing w/ $5 switch.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 03-30-2005, 02:41 PM   #3
atcavage
speaking of killswitches, anyone have a good idea on wiring in a cheapo light switch or a $2 toggle?
1972 1/2 ton Chevy C10 V-8 350, crate engine, with Flomaster dual exhaust. She's Old Blue the Truckinator (no relation to Arnold )
atcavage is offline   Reply With Quote
Old 03-30-2005, 04:34 PM   #4
shifty
Questionable
shifty's Avatar
Easy - splice it in line with the ignition wire - either the one going to the starter or the one between the key and the fusebox.
You can pretty much expect any semi-skilled theif to find either of them unless you have a hood lock and you're hiding the switch in there - but then, if they pop the hood ... better be well hidden!
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
