Got Big Block?
Brake hoses
I talked to a lady from McGaughy's yesterday about brake hoses for my '68 that I'm converting to disc's. The reason I called McGaughy's is that those are the spindles I'm using. She said that I could buy brake hoses for an '80 model camaro and they'd work perfect. Can anyone verify this? thanks!
"Experience is what you get when you didn't get what you wanted." |
![]() Join Date: Jun 2002
Not sure of the Camaro, but the '79 Chevette sounds promising...
http://67-72chevytrucks.com/vboard/s...light=chevette
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Last edited by raggedjim; 04-20-2017 at 10:17 AM. Reason: update link |
I take it you have the original cross memember in your truck with the brake bracket to the rear. I had a problem with my lines kinking, so I went to a braided line with a 90 degree banjo fitting on the caliper. They work fine.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
