Old 03-30-2005, 05:52 PM   #1
r0lf-
Hotwheels?
r0lf-'s Avatar
Drilling front X member
Ok, my bags are going in today. Im currently drilling the crap out of the front X member for the upper plates. Ive been using my drill + jack to get the dang holes done. BUT IT TAKES FOREVER. Granted it IS about 1/3" thick stuff im going through. Im using a Colbalt bit and all, any tips on how others did it?
1978 Money Pit - CUSTOM DELUXE!!!!
r0lf- is offline   Reply With Quote
Old 03-30-2005, 09:22 PM   #2
ureckme
ureckmefixit2@cox.net
DRILL A 1/8 INCH HOLE FIRST. DANG MY CAP LOCK IS ON. once you drill thru than go to a bigger bit. Matt
ureckme is offline   Reply With Quote
Old 03-30-2005, 10:26 PM   #3
r0lf-
Hotwheels?
r0lf-'s Avatar
yeah, im gonna have to do that method tommorow, I killed a unibit today
BUT I HAVE ONE SIDE BAGGED AND BOY DO I GET LIFT! I dont lay out due to the fenders though. Its quite funny lookin having one side low as hell and the other still static.
Old 03-30-2005, 11:05 PM   #4
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
I echo what ureckme said. Start with a smaller bit and step your way up. Use cutting fluid, too. It'll really help. (If you put too much pressure while drilling, you may damage the bits.) Good luck.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
