Old 03-30-2005, 07:07 PM   #1
skokie
skokie's Avatar
Ramhorn Question
I know that the non 4x4s get the angled dump ramhorns and that the 4x4s get the straight dump. My question is why?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 03-30-2005, 07:09 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Location of the engine, and frame/crossmember.
Remember that the 4X4 has the engine further back. If they used the straight dump manifolds, it'd run the pipe directly into something.
Old 03-30-2005, 07:36 PM   #3
MandarinSixSeven
Seasonal Poster
MandarinSixSeven's Avatar
are all straight dump manifolds the same? I have a 2wd and straight dumpers, and the engine is even a 350 on the 6 cyl mounts (thus farther back), nothing hits...
67 GMC Short Step
350/4-Speed/3.08 Posi
Front/Rear Sway Bars
Kelowna BC, Canada
Member of DTPW
MandarinSixSeven is offline   Reply With Quote
Old 03-30-2005, 07:53 PM   #4
69 longhorn
I6 position slides you sb back 3 1/2" from factory spot.....nothing is a clearance prob , except the dist the straight dumps (same as the car manifolds from the same era)......will fit on a sb in factory spot, but trust this crazy old man on this. YOU WILL CUSS ,when you try to get the nuts started on the studs! Been there, done that! Once you slide that eng back 3 1/2", there are no issues on the straight dumps ....... L
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
