Old 03-30-2005, 08:48 PM   #1
woody96
woody96's Avatar
Question Water temp sending unit
Where is the water temp sending unit on a 305? I recently bought an 84 c10, (couldn't help it, added a pix ) silverado with the upgraded instruments with the water temp gauge, and it is not registering at all.......
"Fighting for our freedoms....."
woody96 is offline   Reply With Quote
Old 03-30-2005, 09:04 PM   #2
pedrofixlater
75 STEPSIDE
pedrofixlater's Avatar
the 305's temp sending unit is on the left head by plugs 3 and 5
Pete
75 Chevy Stepside
70 Buick Skylark/GS
pedrofixlater is offline   Reply With Quote
Old 03-30-2005, 09:10 PM   #3
pedrofixlater
75 STEPSIDE
oh ya nice looking truck
Pete
75 Chevy Stepside
70 Buick Skylark/GS
Old 03-30-2005, 11:10 PM   #4
woody96
woody96's Avatar
THX, I'll sure look for it there..........
Old 03-30-2005, 11:46 PM   #5
woody96
woody96's Avatar
Exclamation
Arghhh! Found the sending unit on the drivers side as you said....there is NO wire there, nothing!!! Just the sender........Any ideas as to what I should do next? Help.....!
Old 03-31-2005, 12:47 AM   #6
woody96
woody96's Avatar
Unhappy
As I said, found the temp sender, but NO WIRE---NOTHING but the sender sitting there....didn't see a grn wire hanging anywhere either (haynes diagram shows a green wire for this sender).........any help here would be greatly appreciated to get this hooked up and working.......again, it is a silverado with the better cluster with temp gauge.......
Old 03-31-2005, 01:20 AM   #7
ureckme
ureckmefixit2@cox.net
It's a wire that runs to the main harness on the fire wall. On my truck theres more than one green wire. A/c, fast idle, and temp sender run down the left side of the engine next to the carb and valve cover. some of them run down the block under the Exhost manifold. It could have fallen down the back of the engine. The wire comes out of the harness above the dist. ( on my truck ). when you find the wire ground it out and your gauge should move to hot. Matt
ureckme is offline   Reply With Quote
Old 03-31-2005, 07:58 AM   #8
pedrofixlater
75 STEPSIDE
As you said there should be a dark green wire in the main harness that is hooked up to nothing. As mat said there may be more than one. Find it ground it and gauge will max out. Pete
Pete
75 Chevy Stepside
70 Buick Skylark/GS
Old 03-31-2005, 09:33 AM   #9
woody96
woody96's Avatar
Wink Thanks
THX guys! Appreciated......I hope its there, this 305 has been rebuilt with a cam and such, and non-environmental Edelbrock 1406 carb (no emissions stuff anywhere), so I hope that the wire is there somewhere.......I am finding some things not hooked up or just laying there from the engine transplant.....UGH!!!!!
Old 04-01-2005, 11:00 AM   #10
woody96
woody96's Avatar
Thumbs up
THANKS for the great scoop guys....found the wire/lead hanging off of the side of the drivers side manifold....touched to ground and the gauge pegged....then hooked it up where it needs to be!!! [B]AWESOME help here.....GREAT board, I appreciate it!
