Hotwheels?
Haha, half bagged!
Welp, after a sad day of killing a drill, I am halfway done bagging the front. Its quite fun comparing the ride to static since the passenger side is still static. It rides like buttah, the 3/8" valves are the perfect speed. I get a TON of lift! Heres a mess around crappy pic from tonight...
The bagged side... ![]() The static side... ![]() I also did a writeup on my York install, its in the suspension section. Hopefully Ill have some fully laid out pics tommorow. Oh btw. My LCA's dont lay out, the tires hit the fenders first.
1978 Money Pit - CUSTOM DELUXE!!!! |
Until Seventy Times Seven
Looking good.
I saw your York post and agree with you. You may need to add a bracket on the rear. Are you planning on going with a oil mister or just check the oil regularly? Keep up the progress. ![]()
boxRODz 1983 C10 SWB Fleetside When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son. You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin... |
Hotwheels?
Just check the oil every month and add a ounce or so. Im gonna make up a dipstick for it. Tommorow should bring some money shots if im lucky.
rolf -
The CCI service manual shows how to make a dip stick for the Yorks. Good luck tomorrow.
Inner fenders or outer fenders?
Hotwheels?
Inner fenders.
takem out
are you baggin the back or just front for now...
