Old 03-31-2005, 02:54 AM   #1
CbHeEaVsYt
Pick up man
CbHeEaVsYt's Avatar
Lock up convertor?????????
can anyone tell me wat the point of a lock up converter (i think its tourqe converter????) is i have no idea and i hear it all the time on this site
thanks
cb
heres sum pics of my truck
82 silverado c10
heres my baby
1990 k1500
check out this 1957 chevrolet for sale
CbHeEaVsYt is offline   Reply With Quote
Old 03-31-2005, 10:24 AM   #2
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Older automatics had some slippage all the time. The lockup converter, once you get up to speed, locks up. This means that there is no slippage, lowering RPM and saving gas. Later trucks, like my '86, had TH350c transmissions or 700R4 transmissions, which both use a lockup torque converter.
http://auto.howstuffworks.com/torque-converter3.htm
Earlier pages on this link explain torque onverters in general terms, and this page explains the lockup function.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 03-31-2005, 10:25 PM   #3
Tom
driving is in my blood
Tom's Avatar
Overdrives MUST be locked up while they are in the overdriven gear. Not only does it lower the cruising RPM and save gas, but it also keeps the fluid temps down [slippage = friction = heat] Modern overdrives cut some of the fluid supply to the trans while in the overdriven gear. This is to save on gas even more [not pumping as much fluid means less engine power used to turn pump] but it also means tranny fluid temp is much more critical.
