Old 03-31-2005, 11:42 AM   #1
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
hmmm...turning radius-tie rod question
Okay I have had this problem for a while....I have very poor turning radius towards the passenger side. I was told that maybe the pitman arm was set wrong.....nope....and I was told that my gear box was bad...I doubt it.
SO I decided to take a look at stuff....the steering knuckle that the outer tir rods go into have a little stopper towards the back that will hit a little block on the lower control arm to makle it stop....my drivers side is almost an inch away when turned all the way....the passengers side stops on it.
SO....I looked at my tie rods.....I have a whole lot more thread "out" on the passengers side.....and when my wheels are straight my pitman arm is not flush to the chasis.....like on other trucks I've seen.....
I'll try to get pictures......did I find my problem????
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
Old 03-31-2005, 10:08 PM   #2
Low69CST
The whole stearing my be shifted to one side. Do you know the history of the truck? Take it to a good front end shop and see what they say. Is the Center drag link centered under the truck? (assuming 2wd)
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 04-28-2005, 09:13 AM   #3
mikesz
mikesz's Avatar
Turn your wheel to the left. Turn it to the right and count the turns. Divide by two. Turn back to the left that many times. Your steering box is now centered. If your wheels are pointing left you have found your problem. Chances are somewone did a bad alignment then pulled the steering wheel off and recentered it. Center the box, then the steering wheel, then do an aliginment.
Mike
mikesz is offline   Reply With Quote
Old 04-30-2005, 05:03 PM   #4
1FaastC10
1FaastC10's Avatar
mikesz, you're on the right track. counting the turns to the right, and then dividing by two, turning it back that many turns will cause the wheels to be turned halfway to the right. you need to count the total turns, lock to lock, divide THAT by two. then starting from one lock, turn it the other direction by that number of turns. that should center your steering box.
1FaastC10 is offline   Reply With Quote
Old 04-30-2005, 08:26 PM   #5
mikesz
mikesz's Avatar
I should have said then to make it clearer. But I did say turn to the left. THEN turn to the right. Meaning full left then full right, divide by two. Go back left.
Mike
Old 05-01-2005, 06:21 AM   #6
LONGHAIR
You may have to do the centering twice because of this^^^^^. Since you are being stopped by the stop, you may not get an accurate total count of revolutions. You may have to bring it toward center and then test it again. You could be missing a half turn or more.
LONGHAIR is offline   Reply With Quote
Old 05-01-2005, 10:16 AM   #7
72MARIO
72MARIO's Avatar
I thought that you were supposto have the Idler Arm and the pitman arm straight with the frame rail.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
