Old 03-31-2005, 02:24 PM   #1
ryanroo
ryanroo's Avatar
Alternator ???
I was wondering if there is a way to find out it the alternator on my truck is extenally or internally regulated. it is starting to howl intermitenly and i have an alternator i took of a 77 chevy that i can toss on it, but im not sure if what i have os internally regulated. thanks for the help
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 03-31-2005, 02:30 PM   #2
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
If it has a square plug its external, blade run (II)
If it has a rectangle plug its internal,blades run(- -)
sneakysnake is offline   Reply With Quote
Old 03-31-2005, 02:32 PM   #3
ryanroo
ryanroo's Avatar
thanks very much, must be internal, because i has to use a the (- -) to hook it up
Ryan
72 K20 12v build
Old 03-31-2005, 03:13 PM   #4
nathank
resident geek
nathank's Avatar
Externally regualted should have a regulator mounted someplace too.. little black box looking thing.
71 C-10 stepper
88 Moostang T-Top w/ lots of goodies
nathank is offline   Reply With Quote
Old 04-03-2005, 11:12 AM   #5
Bstang
Sounds like you have a external regulator may be mounted on the rad. support assy. on the drivers side under the head lights a black box about 3 inches square with a flat plug. Sounds like a bad diode in the alternater, pull alt. and reg. off and have both checked repairs to alt. cheap, and if it's been on a while it's time for brushes and bearings anyway.
Bstang
Bstang is offline   Reply With Quote
Old 04-03-2005, 12:18 PM   #6
VetteVet
Msgt USAF Ret
VetteVet's Avatar
alternators
here's some good info on the alternators
http://www.madelectrical.com/electrical-tech.shtml
VetteVet
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 04-03-2005, 05:06 PM   #7
nathank
resident geek
nathank's Avatar
If you do have an externally reg unit, might as well go ahead and convert to an internal reg unit. I picked up a 10si for under $40. Not a bad price for an alternator.
71 C-10 stepper
Old 04-03-2005, 08:10 PM   #8
CHEVIBUBBA
got boost?
CHEVIBUBBA's Avatar
or; you can use the one you have from the '77.
just use the instructions from mad.
'70 chevy lwb w/'67 hood.
357 s.b.c. built, 4l60 w/vigilante lockup high stall converter, edelbrock pro-flo,brodix heads,comp cams rollerized w/ belt drive, one piece d-shaft, yada, yada, yada.....
'82 honda v45 sabre"the black"
CHEVIBUBBA is offline   Reply With Quote
Old 04-03-2005, 08:15 PM   #9
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
External Box
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 04-04-2005, 02:51 AM   #10
ryanroo
ryanroo's Avatar
well the voltage regulator is there, but im not sure if it is being used. the current engine came out of a 76 and has the alternator on the wrong side for our era trucks. i also know i had to convert the wiring harness to the horizontal plug style from the vertical to make it work, and the alternator is the same as the one from the 77. so any advice on how to tell if its being internally or externally regulated? thanks
Ryan
72 K20 12v build
Old 04-04-2005, 12:06 PM   #11
sneakysnake
eliminate the external reg.
Old 04-04-2005, 03:57 PM   #12
ehjorten
So...you say that it is starting to howl. Sounds like the rear bearing?! If you converted, or it was converted...does it have the rear bearing support bracket attached? If not, this is accelerating your rear bearing failure! Many times people neglect this bracket when converting their vehicles (the bolt hole location changes from a DN to SI alternator).
'68 Chevy Stepside in Frame-up Restoration process.
292 CID Clifford Performance Modified
T56 6-speed Tranny
Slammed, Custom IFS and IRS
Money?...Too Much!
ehjorten is offline   Reply With Quote
Old 04-04-2005, 04:19 PM   #13
67chevemall
67chevemall's Avatar
^ good point! Also make sure the grounds are good on the voltage reg!
67chevemall is offline   Reply With Quote
