Old 03-31-2005, 07:32 PM   #1
78 chevy truck
air in line
i keep getting air in my driver front brake line when i bleed the brakes. i can not find ant leaks all the other brakws worked find any help would be great
78 chevy truck is offline   Reply With Quote
Old 03-31-2005, 08:07 PM   #2
full foot notch
tried some russell speed bleeders, works for a one man job and has a ball that closes when the line feels a vacuum(ie pedal going back up), should maybe be $20 total
full foot notch is offline   Reply With Quote
Old 03-31-2005, 08:26 PM   #3
78 chevy truck
i got a bleeder lit and clear hose and i see is a ir in the line every time i bleed the brakes only the driver side . and i have power brakes if that matteres
Old 04-01-2005, 01:36 AM   #4
Elsie72
Chinook Arch
Elsie72's Avatar
I had a hydraulic clutch on a bike 'ingest' air over a day or two, and the source of the leak turned out to be the hose, where the end crimped onto the hose. I could bleed the clutch, but a day later, there was no clutch due to the air. Replaced the line with a braided steel line, and no more trouble.
1972 GMC 1500 Custom - Bought used by Grandpa in '74, currently back on the road after a long hiatus.
Elsie's truck
2.5" dual exhaust with Hooker Aero Chambers
Holley 670 Street Avenger Edelbrock Performer RPM on GMPP 290HP 350
ECE drop 3.5/5
Elsie72 is offline   Reply With Quote
Old 04-01-2005, 09:24 AM   #5
smokekiki
Mike
smokekiki's Avatar
If Your hoses have never been replaced,they are 27 years old.New lines are a wise investment.Braided lines will make a difference in the braking.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
