18 Till I Die
Alum bushings for rear trak bar
1967-72 GMC ..Anyone ever remove the rubber bushings and install aluminum ones, or is it better to go to poly from energy suspensions
You could make one with a lathe, but i doubt you'd notice the difference between that and poly. Poly is what i'm using by the way.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
Save yourself the trouble, have a look at these (about half way down the page).
http://www.stockcarproducts.com/trkarm.htm
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
