03-31-2005, 10:21 PM | #1 |
Still drivin' a Rat Rod
Driveshaft Lengths
I thought I posted this once,but couldn't find it,so here goes.
I am switching to an automatic in a few weeks.Now will the driveshaft from my 4 speed work with a short shaft 350 turbo if I put the yoke on it? Also I have a longshaft 350,is this better than the shorty?I am going to have one rebuilt,and I have a long and short tranny.Is it worth having a shaft made to use the long shaft?
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
03-31-2005, 10:44 PM | #2 |
its all about the +6 inches
IF your current shaft won't fit with either TH350, and you have a short and a long in comparable condition, I would opt for the long shaft myself.
While it isn't correct, it'll be easier to get a replacement tranny later since short shafts are getting harder and harder to get, plus, a few inches makes a huge differance when tryin to do a one piece shaft. |
03-31-2005, 11:33 PM | #3 |
I'd go with the long tailshaft because thats what they had . Drive shafts should be
as common as dirt and about as cheap. Just advertise here for one and see what comes up. J Y |
04-01-2005, 12:23 AM | #4 |
JYdog...all the 67 - 72 trucks originally had short shaft trannys.
04-01-2005, 01:45 AM | #5 |
So if I go with the shorty,the driveline from my 4 gear will be the same length once I put a yoke on it?
04-01-2005, 06:22 AM | #6 |
You're right L M I promise not to post under the hinfluence again.
Jim |
04-01-2005, 06:42 AM | #7 |
Been there, done that. |
