KEEP ON TRUCKING
bbc help searched with no luck
i bought what i thought was 72 bb towers/motor mounts.
i dont have a pic but i think theyre 73 up sb.they line up on frame rail and one hole on crossmember but 4th hole is way off on crossmember.they use the tower/mount/ and clam shell that bolts to block and use the long bolt with a nut that runs front to back thats about 5in long. will they work with my 402 and headers/th350 with out much problems in a low hump cab. and if so will 3 bolts on tower hold it or do i need to drill the other hole in crossmember.thanks for the help henry
72 cheyenne 2wd lwb 71 k20 sons bassett va |
Got big-block?
![]() Join Date: Jul 2000
here's a couple of pics of the factory mounts out of my '77 3/4 ton 454 truck. Hope it helps:
'68 CST SWB factory 396/T400 buddy buckets, a/c, ps, pb '72 Corvette convertible 454/4spd/ac, ps, pb '73 GMC Sierra Grande short wide 454/T400 ps, pb, ac '77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original '78 GMC Sierra Classic short wide 454/T400 ps, pb, ac '72 GMC Sprint SP454. 1 of 38 built. '73 GMC Sprint SP454. 1 of 71 built. '75 GMC Sprint SP454. 1 of 25 built. SOLD! '72 GMC K25 4x4 468/4L80e/NP205 build thread http://67-72chevytrucks.com/vboard/s...23#post4324423 SOLD!'55 Chevy gasser 496/4spd build thread http://67-72chevytrucks.com/vboard/s...96#post4324396 |
#3 | |
KEEP ON TRUCKING
55454
The protrusions are the top of mount usually signify 1972 BB, please correct me if I am incorrect.
Thanks |
![]() Join Date: Aug 2001
THAT MOTOR MOUNT PICTURED IS A 73 ON UP M/M. THE HOLES FOR THE TOP FRAME RAIL ARE ABOUT AN INCH & A HALF CLOSER TOGETHER ON 72s, & ARE YEAR SPECIFIC. (MEANING THEY ARE A ONE YEAR ONLY ITEM) JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
#6 | |
Resident Curmudgeon
![]() Join Date: Dec 1999
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
![]() Join Date: Apr 2000
Yes when I did the BB swap with 72 towers I had to drill the 4th hole too.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
#8 | |
KEEP ON TRUCKING
does anybody have a pic of 72 bb motor mount are they close to the 77
72 shadetree i did the exact swap your talking about, you,ll have to drill the fourth hole like they said. i put a bb and th-400 under a low hump floor and if fit really well about a inch or two clearance from the floor too the tranny.I used ceramic dynomax hearders for the 67-72 cheavy truck and they fit really nice with no problems with the factory short shaft accesories. hope this helps john
69 chevy short wide box project 70 GMC jimmy project |
