Old 04-01-2005, 05:49 PM   #1
Crazy-J
Crazy-J's Avatar
Heater duct; what tape to use?
Hi all,
I recently installed a heater/defroster from vintage air (just a heater, no air conditioning).
Because of the difference in size of the duct coming out of the heater to the larger duct needed for the defroster vents I am using two different sizes and I need a way to keep them together where one hose ends and the other begins.
I tried duct tape but it just burned right through. I next tried some heater hose wrap tape that worked for a little bit and didn't melt but it won't stay stuck to the ducting.
Any idea on what tape to use?
Crazy-J is offline   Reply With Quote
Old 04-01-2005, 06:52 PM   #2
stickshift_or_walk
Left Foot Functioning
stickshift_or_walk's Avatar
Locate a dealer for residential heater/AC parts and supplies, or a local HVAC contractor. They use a tape that is similar to thick aluminum foil with a really strong adhesive for various ductwork issues. The roll I have is about the same size as a role of duct tape, but it comes with a peel-off backing because once it's stuck, you can't get it off in one piece.
SSOW
69 C10 (#1 son's ride)
72 C20 (Dad's farm truck)
82 K30 (Ex - brush pumper project)
stickshift_or_walk is offline   Reply With Quote
Old 04-01-2005, 06:59 PM   #3
Fred T
Cantankerous Geezer
Fred T's Avatar
You can buy the aluminum tape described by SSOW at a hardware store. However, I don't think it will work either. You need an adapter fitting to join the two hoses. I'd start by contacting Vintage Air.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 04-01-2005, 09:49 PM   #4
jhow66
jhow66's Avatar
Check out the PVC connectors at Home Depot etc.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 04-01-2005, 10:23 PM   #5
barn9
Half a bubble off!
barn9's Avatar
Plumbing supply or hardware store should have a selection of reducers, and hopefully something that will work for you. Or in other words, what Fred and jhow66 said.
Just call me LB.
'71 Cheyenne, 402BB, hauls blondes, brunettes, or redheads.
barn9 is offline   Reply With Quote
Old 04-02-2005, 12:22 AM   #6
mocwon
Keep On Truckin'
mocwon's Avatar
Fred's right... I got the adapters from Vintage Air. I'm installing mine tomorrow and plan to use the aluminum foil tape at the joints so they don't slip apart.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
