18 Till I Die
69 Rear Trailering Arm Bushings
Can you remove the rear trailering arm bushings in the truck by dropping the fronts or do you have to remove the arm and press them out? I want to replace them with polyurathane from Energy ....69 GMC long box
Location: Help! I'm in an office park with its own network of freeways!
You could press them out. However, if the bushings you are installing have no outer shells, there's an easier way. Burn 'em out.
In any case, I'd remove the arm.
'67 C20--427 tall deck/SM420, 4.10 HO52 (Michigan has not been kind to the Old Man) '95 Caprice--355 LT1/T56/3.42 8.5" 10-bolt (daily driver, almost 300k on the chassis) '07 Outback--wife's car. 125k & counting. No head gasket or transmission issues yet. *fingers crossed* |
