Got Light Emitting Diode?
head bolts
when puting a new set of heads on would you change head bolts or use the old ones. i just bought some ZZ4 heads and am trying to justify the 145 for ARP stainless bolts.
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
Saving 1 truck at a time!
All my performance engine building books say to change them to studs. I have built stock daily drivers without changing bolts and have not had a problem. If it is a performance motor I would go with studs...more accurate and consistent torque readings.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
I hope this will make it a performance motorh
![]() ![]() http://store.summitracing.com/defaul...h.asp&N=400295
its all about the +6 inches
Old bolts are streached out and will not give acurate torque readings.
However, a street motor will never know the difference. |
#5 | |
#6 | |
Project 2 Resume
http://www.centuryperformance.com/fasteners.asp The stud to the left or bottom, is undercut.
John 1984 C30 Chevy Crew Cab Dually 1998 Jeep Cherokee 4x4 2004 Chevy Trailblazer 4x4 (wife's) 1970 Mustang FB fully tubed (getting 521 BBF & powerglide) 1978 Nova 2dr (going BBCaddy & S.P. th400) 1984 Monte SS (circle track car) |
Cantankerous Geezer
You do need to replace the bolts due to fatigue, cracking and stretch. Studs are nice, but not necessary for most. They do make it easier to swap heads. Scoggin Dickey sells bolt kits at a decent price. ARP makes good bolts, but unless you're doing a high performance build they are expensive.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
Used head bolts are scrap metal.
#9 | |
For every person with a spark of genius, There are a hundred with ignition trouble. ![]() |
68cst_ss490
spring for the arp headblot...more accurate torque and peace of mind in my opinion. plus the arp blolts look cool with aluminum heads
Dean edmonton,canada a winter wonderland 2005 Chevrolet Avalanche LT cold air intake, performance exhaust, Comp cams cam, jba shorty ceramic headers. http://www.cardomain.com/ride/3090973 |
#11 | |
68cst_ss490
Ya get the gf to buy them......then buy more stuff for yourself.LOL
#13 |
then i can buy the carb spacer i was asking about in another thread. and get my ZZ4 heads looked at by a head shop and have them doo the steam holes too. she gets the 140ish bill i get the 110, but them i still have to buy gaskets, not to mention the heads i already bought. hey i might even let her drive it
#14 |
68cst_ss490
LET HER DRIVE IT!!!!!!! I think you should lay down and relax...you may be overworked you're starting to talk crazy.
lmao just kiddin. If she wants to but the parts its the least you could do
#15 |
i have let her drive it, but she could drive it more
#16 |
Just Don't Stop!
![]() Join Date: Feb 2004
I let my girl drive my truck twice. I've NEVER seen her with a bigger smile on her face, lol.
1968 C10 build in process TT LSA/6L90e/9" |
#17 |
F.A.S.T. president
![]() Join Date: Sep 2003
You dont have to use the ARPs.....you can just run GM bolts...just make shure they have the correct washers, because thats a "must" for aluminum heads.
Old head bolts are fine in most cases. but a new GM set are around $30 fro cast iron heads. The only bolts you CANNOT reuse are "Torque to yield" , but then again under that shade tree CANNOT turns to SCREW IT I'M GOING TO SELL IT ANYWAY........
F.A.S.T. President and Founder Fabricators for the Advancement of Sawsall Technology "A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis" Last edited by jamis; 04-02-2005 at 10:32 PM. |
#18 |
68cst_ss490
the gm bolts new from gm probably arent any cheaper from gm than a set of ARP
#19 | |
F.A.S.T. president
F.A.S.T. President and Founder Fabricators for the Advancement of Sawsall Technology "A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis" |
#20 |
68cst_ss490
the black oxide ones look great with aluminum heads. Thats what i used on my small block
#21 |
Dean...how do post that big picture in your message? I thought we could only upload like 642 x 642 or something?
My buddy let his wife drive his 502 ci/550 hp El Camino...once! She got on it at about 45 mph and did one huge donut...parked it in the middle of the highway...stopping traffic. He was following and had to get in and finish driving it to the show. She drove his truck...LOL!
#22 |
stllookn, right click on the image and then click properties. It is hosted on imagestation not this board.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
#23 |
68cst_ss490
all did was copy the properties from imagetstation where i had it enlarged. and it comes out that big on here.
#24 |
black oxide bolts look good. i might get those.
P.S. nice valve covers. i have them but in black
#25 |
Nice looking engine, what is that serpentine system off of and will one fit on my 86 block?
