04-02-2005, 01:46 AM | #1 |
Professional Grade
Converting flare fittings to o-ring fittings?
hey guys!
Is there an adapter out there that will convert a flare fitting to a chevy style o-ring fitting? I've got a steering box on my 4x4 frame with flare fittings, but I want to run my serp power steering pump, and it has o-ring fittings (I think they are named saginaw fittings?)
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
04-03-2005, 02:24 AM | #2 |
Lee Steering has them. I don't think they have a website, but here's their phone number:
Lee Manufacturing Co. 11661 Pendleton St. Sun Valley, CA 818/768-0371 |
04-03-2005, 09:39 PM | #3 |
Id try local first just incase. Try a place like Gregs distributors (they supply all the fittings for the Vinmars at work)
Ben 1983 Silverado SWB 305 2002 Silverado Extended Cab 5.3 http://members.shaw.ca/bkennett |
04-03-2005, 10:18 PM | #4 |
The fitting on the back of the power steering pump screw on and off, atleast they did on the 88 parts truck I got the belt off of, and the pump for my 83.
'96 Nissan Pathfinder '02 Firebird Trans Am. '88 K5 Blazer |
04-03-2005, 11:43 PM | #5 |
Professional Grade
Hmm, I must be crazy, cause I could swear that the fittings on the top of the power steering pump were cast into it?
I'll look tommorow, cause if that is the case, then I can just move the fittings from my 80's steering box to the K25's Unless, of course, I can put the 2wd 80's steering box onto the K25...
04-03-2005, 11:55 PM | #6 |
when I put the serp setup on my 85 I didnt change anything. Never had a leak.
Youth soon passes away, but immaturity can last a life time. |
04-04-2005, 01:24 AM | #7 |
Professional Grade
Yeah, starting in 80 they put o-ring style steering boxes on the trucks, unfortunately, my K25 chassis is from a 79 and still has the flare fittings
04-04-2005, 06:44 PM | #8 |
the pump will just thread out, the box will have to be changed.
