Old 04-02-2005, 01:19 PM   #1
fine 67
Junior Member
3:07 gears
i"m doning a full frame off on my 72 blazer . new motor/tranny both 350's with 3:07 gears and L 78 -15 or p 235 will the truck be a gutless slug.are 3:73 the way to go thanks
fine 67 is offline   Reply With Quote
Old 04-02-2005, 01:32 PM   #2
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
3:73 are an all-round good gear ratio.Good in the city and fine at hwy speeds.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 04-02-2005, 01:45 PM   #3
3chevys
Junior Member
3chevys's Avatar
I have both 350's as well with 4:11, and was told by club members that 3:73 is the way to go.
3chevys is offline   Reply With Quote
Old 04-02-2005, 04:20 PM   #4
bpmcgee
bpmcgee's Avatar
Well, that's a religious question. Personally I find that my Blazer with 3.07s isn't slow at all. It's not a hotrod, but I built it trying to get good gas mileage, not burn rubber.
Brian
bpmcgee is offline   Reply With Quote
Old 04-02-2005, 11:27 PM   #5
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
My '72 has 235/85R16 and 3.07's. It is a stock combo so it is definately very driveable. I don't notice any lack of power in my truck, but I would like to swap up to the 3.73s and get a slightly larger tire. My '69 has 4.10's with 35" tires but since that truck has a built 350 and a shift kit, it is hard to judge the difference.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 04-03-2005, 12:45 AM   #6
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I really like my 3:73's with the 32x11.50 tire and a crate motor moves it pretty good..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 04-03-2005, 01:12 AM   #7
Jimmy72custom
Jimmy72custom's Avatar
I'm running 260 hp 350ci, SM465, 307 gears, 33x12.50x15. I'm turning about 2200 rpm @ 65 mph in fourth gear.
Jimmy72custom is offline   Reply With Quote
