06-07-2002, 06:50 PM | #1 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
*pic's* of 12 bolt rear disc brake install in my 71 Blazer
Finally finished my rear disc install on my 71 Blazer.I used the TSM kit.It took me about 2 days(taking my time)and went real smooth.
I am having trouble getting the air out of the system(see my post-CAN'T GET A HARD PEDAL) so the jury is out on any braking performance improvments as of yet. Total cost was roughly $400.00.Prob. could have done it a little cheaper but I went with new parts instead of used ones. Click the link to see the pic's. http://www.imagestation.com/album/?id=4292219125
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
06-07-2002, 07:28 PM | #2 |
Nice job and nice documentation of it.
Saskatoon, Saskatchewan Canada |
06-07-2002, 07:30 PM | #3 |
Checked out the pics, man looks like you did a hell of a job! Come on over, lets get started on mine! I got a fridge full of beer!
68 SWB The Surgeon General doesn't say anything about smoking a Ford!!! Would rather be ran over repeatedly by a Chevy than drive a Ford!!! Paralyzed from the neck up and confined to a hat! Kathleen, Georgia USA |
06-07-2002, 09:33 PM | #4 |
oh man, that would make a great tech article for my website..
would you be interested in writing one up? you can basically just write in the instructions and i'll go through it and make it more readable of course, you'll get full credit.. lemme know if you're interested as I'd like to do this swap myself and your pictures would be the perfect addition to a good writeup thanks, Colin
Webmaster: www.h-body.org |
06-07-2002, 10:18 PM | #5 |
I Love This Stuff!
Very Nice
Awesome pictures
You have given me a lot of confidence to do mine!!! JHickson6 |
06-08-2002, 12:08 AM | #6 |
Colin,no problem use the pic's if you want.Let me know what kind of description you want and I'll do my best to describe the steps of the install.
JHickson6,I'm from Winnipeg as well but at present working in California.I'll be in the "peg" in Aug. but not with my Blazer. Glad you got something out of it.That's the main reason I document the mods I make.I know if I'm up in the air about doing a mod. and I see pic's of how some-one else did it it really helps me. I give credit to a guy named Steve Chin,he's a member at coloradok5.com.He did the swap before me and did a excellant job writing it up,just no detailed pics.Still his article helped me GREATLY!!!
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by BobbyK; 06-08-2002 at 12:12 AM. |
06-08-2002, 12:17 AM | #7 |
Nice job! What do you use to get those nice looking pics?
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
06-08-2002, 12:35 AM | #8 |
I use a Nikon digital camera.It's a COOLPIX 880.Takes great pic's.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by BobbyK; 06-08-2002 at 06:35 AM. |
06-08-2002, 12:08 PM | #9 |
Hey Bobby,
Basically, whatever you can writeup will be fine. I've been looking for quite awhile for the details on this swap so any information that you have will be great Maybe you have the part numbers of the parts that you used (seals, bearings, etc) or something. Any installation instructions oyu want to add and any tips that you might have that would be useful would be great, too I'll see if I can work out some compensation for you because it'll be a fairly extensive article. I can probably fire you off a few bucks to write it up.. Thanks again man, Colin
06-08-2002, 12:10 PM | #10 |
oh, here's one i wrote on how to change your EGR on a tuned port injection engine
http://www.gmperformance.org/modules...rtid=10&page=1
06-08-2002, 03:55 PM | #11 |
Cool. Nice to know you can get a kit with e-brake for that price. Nice job on the photos. Did you ever get the air out of them?
06-09-2002, 12:41 AM | #12 |
No not yet.I work nights all weekend so I'll get back to it on Monday.
ColinOpseth,once I get all the air out of the brake system and have it up and running I'll put together a small write-up describing the steps I went through during the install.I'll enclude any part Numbers I have as well.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by BobbyK; 06-09-2002 at 12:48 AM. |
06-09-2002, 12:54 AM | #13 |
hey Bobby,
thanks so much, dude.. i really appreciate it you'll get full credit on my site, of course
06-16-2002, 11:05 AM | #14 |
BobbyK,
did you get the e-brake hooked up? If so, how does it work? Thanks |
06-17-2002, 01:32 AM | #15 |
Yes I did.I reworked the factory e-brake cables and was able to make things work.
1st I took the orig. e-brake cables off the truck. 2nd-I enlarged the holes on the e-brake cable braket (on the new Eldorado caliper)so the factory cable would fit(just filed it out a little) 3rd-I cut about 2" of the end of the orig. brake cable. 4th-removed the spring that's on the orig. e-brake cable. 5th-put a grade 8 nut over the cable end and with a BFH smushed it so it is clamped onto the end of the cable. 6th-re-installed old cables back into the truck. 7th-adjust the 2 nuts on the cable that goes to the brake lever in the truck to get the slack out of the cable. 8th- applied the e-brake about 6-10 times to set the brake pads on the rear disc brakes. The e-brake works well.If your vehicle is lifted you will need longer e-brake cables. I didn't take pic's of me doing this but if anyone needs pic's I'll go and take pic's of whatever you need.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by BobbyK; 06-17-2002 at 01:34 AM. |
06-17-2002, 10:38 AM | #16 |
You did a nice job.What size are the discs ? Who's calipers are used ?
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A> |
06-17-2002, 03:23 PM | #17 |
Bobby who is TSM? Every kit I looked at was about $500. thats a good price.
1980 Chevy Shortbed Pickup 1969 Z28 engine Turbo 350 |
06-17-2002, 08:18 PM | #18 |
The rotor are about 11" across.the rotor are just the ones used on the front disc brakes.Six new 7/16 holes are drilled in them to fit the rear axle.
The Calipers are from a 84 Cadillac Eldorado. Here is a link to the TSM site. http://tsmmfg.com/General_Motors_truck_rear_axles.htm
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by BobbyK; 06-17-2002 at 08:21 PM. |
