Old 04-02-2005, 08:44 PM   #1
rusted75 half ton
More trusty Less rusty
rusted75 half ton's Avatar
Exclamation Needed to buy 71-87 4x4
My daily driver died ,need to find something soon so I thought I'd try here first.Not picky all I need is a chevy/GMC 4x4 between 71-87 can be auto or manual I-6 or V-8,and not require any major repairs,something between $1200-$2500.Needs to be locall too,Just no big blocks or early V-6's.PM me or post a reply.Thanks
rusted75 half ton is offline   Reply With Quote
Old 04-03-2005, 12:48 PM   #2
rusted75 half ton
ttt
Old 04-03-2005, 08:40 PM   #3
1970c10sb
to bad you arent near indiana, my 76 would be perfect for ya
1970c10sb is offline   Reply With Quote
Old 04-04-2005, 03:35 AM   #4
highboy_04
highboy_04's Avatar
how did your dd die? i used to live in lakewood by the way.
'67 c10 350/th350
highboy_04 is offline   Reply With Quote
Old 04-04-2005, 09:26 AM   #5
rusted75 half ton
Quote(how did your dd die?)Pretty much everything bad valve,thermostat broke,Brake m/c leaking ,an electrical problem,trans is not going into third and fluid smells burnt,haven't checked it out but a horrible screeching from the Drivers side wheel.I wouldn't mind fixing it all if I had something to work with,but every body panel has at least one rust hole and dent and a lot of bondo covered rust.I got alot of use out off it so I feel I should move on.
Old 04-05-2005, 02:57 PM   #6
highboy_04
highboy_04's Avatar
oh... well if i had something i'd hook you up. good luck. steve
'67 c10 350/th350
