Old 04-02-2005, 10:24 PM   #1
new271
new271's Avatar
What Standard Trans will fit?
Hey guys/girls,
Need a little help.What 4 speed will bolt up in my truck with the least amount of mods.(Do not want granny gear trans)?My truck is a 71 swb,2wd 1/2 ton,307,3 speed (already a floor shift) 2 piece drive shaft,5 bolt wheels.Should be all the info you need.
prefer a car type trans.Muncie out of budget
new271 is offline   Reply With Quote
Old 04-03-2005, 06:30 AM   #2
shifty
Questionable
shifty's Avatar
It was suggested the other day that an S-10 5spd tranny would bolt up to my inline 6, not sure if that is also true with your setup.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 04-03-2005, 12:23 PM   #3
jhwkns
Registered Cruiser
jhwkns's Avatar
I'm using a Saginaw 4-speed from a 82 Camaro. It's the same length as your three speed. No driveline mods are needed. With a Hurst shifter, and the linkage kit designed for our trucks the shifter position is far enough forward to use it with a bench seat if you desire.
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 04-03-2005, 02:16 PM   #4
jcueckert13
jcueckert13's Avatar
the trans is a t-5 and ifyou go that routeyou need to find one that is a world class that is out of a camero and was origionaly behind a 350. the ones in the s10 are non world class and do not stand a snow balls chance in hell of holding up behind a real engine.
1990 subaru legcy (daily driver)
1987 Toyota 4runner (weekend toy)
1968 C30 flatbed dually
1970 C10 longbed stepside (in pieces)
1976 Dodge Dart
1963 Dodge Dart
jcueckert13 is offline   Reply With Quote
Old 04-03-2005, 03:06 PM   #5
MandarinSixSeven
Seasonal Poster
MandarinSixSeven's Avatar
I too have a saginaw 4-speed from an 80's camaro, it fit in perfectly both in length and number splines on the input shaft...
67 GMC Short Step
350/4-Speed/3.08 Posi
Front/Rear Sway Bars
Kelowna BC, Canada
Member of DTPW
MandarinSixSeven is offline   Reply With Quote
Old 04-03-2005, 03:39 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Originally Posted by jcueckert13
the trans is a t-5 and ifyou go that route you need to find one that is a world class that is out of a camero and was origionaly behind a 350. the ones in the s10 are non world class and do not stand a snow balls chance in hell of holding up behind a real engine.
This is not entirely acurate.
They NEVER sold a camaro nor firebird with a 5 speed and a 350. (from 82 to 92...3rd gen f-body car) If you wanted a manual, then you had to get a 305, or smaller.
Not all 305 camaros had the world calss tranny.
The world class one...the strong one, is only rated at 305 ft pounds, and when you start adding heavy vehicles, (truck) then it get stressed even more.
The garden variety T5 is only rated at 280 ft pounds.
Now, with all that being said, putting one of these trannys behind an inline 6 or a 307 would be awsome, esp with a 3.73 or 3.40 gear. If you had a stock 350, and didn't push it very hard and didn't haul/tow too much, then it would probably hold up for a while, however, they are still fragile, and spinning the tires in snow or on wet pavement and getting sudden traction is murder on these trannys.
Old 04-03-2005, 04:01 PM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The parts are out there to build a T5 to pretty much any level you can afford. I have pretty strong one in my Mustang. It cost some bucks though. There are some 5 liter guys running under 10 second quarter miles times with a T5.
I'd imagine Shifty's little 250 inline wouldn't pose much of a challenge to the stock S-10 T5 though.
Old 04-03-2005, 07:15 PM   #8
shifty
Questionable
shifty's Avatar
I've got some weird crossmember in mine, apparently. Everyone keeps telling me it's odd (there are pics in my "engine swap" link below).
Do the camaro 4spd and s-10 5spd trannys have multiple mounting holes to fit diff't types of x-members?
Old 04-03-2005, 11:07 PM   #9
new271
new271's Avatar
Do I use the original bell housing and clutch set up from the truck or do I need the Camaro.
Old 04-03-2005, 11:12 PM   #10
jhwkns
Registered Cruiser
jhwkns's Avatar
You use the truck bell housing.
Old 04-05-2005, 10:49 PM   #11
JodysTransmissions
JodysTransmissions's Avatar
Thumbs up
A Muncie 4 speed from your late 60's or early 70's passenger car will be a bolt in for you. It will also take the abuse.
Regards, Jody
JodysTransmissions is offline   Reply With Quote
Old 04-06-2005, 09:58 AM   #12
jtminton
II Timothy 4:2
jtminton's Avatar
Here's one for you.
72 C-20 2WD LWB Custom Camper Deluxe 350 4 Speed "Project Lazarus"
MY TRUE PRIDE AND JOY
"Dangit, Bobby, people will see that oil stain and think I'm a drunk."
jtminton is offline   Reply With Quote
Old 04-06-2005, 11:16 PM   #13
new271
new271's Avatar
Thanks for the help.Not sure what to do yet.I have a rebuilt 700r that came with the truck.So I'm still figuring what route to take.don't let me hold you up on the purchase.Our big swap meets are coming up (Spring Carlisle) and I'll be their selling Goodmark parts for my buddy.I'm sure I will come across one later when I make my mind up.
