Old 04-03-2005, 02:14 AM   #1
53burb
53burb's Avatar
Replacement engine
Once I get my starter situation straightened out, I am going to start considering an engine replacement. I have decided to either go with this stock replacement engine engine and upgrade it with an Edelbrock cam, lifters, and intake manifold set. Or this one,engine and just add an intake manifold. I want it to be in the 300-350HP range. It will have dual exhaust w/rams horn manifols and I will be using an Edelbrock 1806 650cfm carb and HEI iginition. What value does Vortec heads have? Both engines are 4-bolt mains. The stock one uses a 2-piece rear seal and the 330-HP uses a 1-piece seal. Also, is it recommended to use a HV oil pump?? The tranny is another story.
53burb is offline   Reply With Quote
Old 04-03-2005, 02:17 AM   #2
53burb
53burb's Avatar
Sorry, the links didn't work correctly. Anyways, the stock one is the one for $1419 and the other one is $2395 & 330HP.
Old 04-03-2005, 02:48 AM   #3
1STtimePRo'71
1STtimePRo'71's Avatar
Might think about posting this in the Engine threads. You may get better answers there.
-Cory
1967 2 Wheel Chevy
1STtimePRo'71 is offline   Reply With Quote
Old 04-03-2005, 03:03 AM   #4
53burb
53burb's Avatar
Thanks, I just did that.
