Old 04-03-2005, 08:53 AM   #1
Clos'84TX
Foom, foom, foom!
Clos'84TX's Avatar
C10 suspension VS C20 suspension
Do the leaf springs and hardware differ between a C10 and C20?
Reason I'm asking is because my truck was converted from a Diesel to a gas 350 q-jet set up. I've very certain my suspension was never changed over. Because I still had diesel type rear end gears.
I plan to drop my truck to 3/5 drop. Do I need to buy all matching leaf springs if I use a rear flip kit? Made for a C10 If infact my rear suspension is big (heavy duty).
- Dan
84' LWB C10 // 2.5" from collector back. duel Turbo
Mufflers // 350 w/ TH350
long Headers//3.73 rearend gears
Future Mods
3/4 suspension drop
Clos'84TX is offline   Reply With Quote
Old 04-03-2005, 12:19 PM   #2
Streetmaster
Dont know how thick your springs are, but if there any thicker than mine which are 3 liefs with a real thick lief on the bottom as a helper spring, then i would because the thing might ride really rough over R/R trax, and pot holes, and such. I remember even with the springs i've got, they made it seem that the pore bed was gonna fly off after i hit a rough set of tracks a little to fast, but that was before i tore it all down to do a grownd up resto. Good Luck
Streetmaster is offline   Reply With Quote
Old 04-03-2005, 04:04 PM   #3
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
What you will need to find out is if you have 52in leafsprings or 56in leafsprings (HD). What year and load capacity (1/2-3/4-1 ton) is the truck your talking about? What type rear end does it have (10 12 or 14 bolt)?
http://www.eatonsprings.com/measuring.htm
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 04-05-2005, 12:17 AM   #4
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
The size/length of the springs won't matter for a flip kit though.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 04-05-2005, 11:21 AM   #5
Clos'84TX
Foom, foom, foom!
Clos'84TX's Avatar
thanks for the help.
- Dan
Future Mods
3/4 suspension drop
