Surly*Speed*Demon
1987 2wd 350 headers help?!
I just put a set of headers on a 87 gmc r1500 2wd 350/m20. The problem I am having is the driverside collector is pointing right at the tranny crossmember
What type headers are you using? Shorties or full length. I have the Edelbrock shorties w/ AIR injection on mine and the only thing that I had to do was to have a smaller size pipe installed because the headerflang was a little smaller than the original manifold flang.
Surly*Speed*Demon
Flow tech full length. I removed the air inj. pipes and pump.
BAD BOW-Silverado XST
What you need is a dual hump crossmember from a 1 ton truck. Or build your own. A board member made this crossmember for my truck. A dual hump crossmember is almost the same design but stock. Some board members have the dual hump crossmember too.
Parts and more parts
A good muffler guy can get around the cross member. I have headers on my son's truck (86 Chevy and my truck 84 GMC and with both of them we just angled that side a little to clear the member and then completed the pipimg run. Both trucks are lowered 31/2" and there are no clearance problems.
We just welded two 3inch turn downs together to make a kick up, it was cheap and it works. No real point in making a custom crossmemeber unless you want to.
'96 Nissan Pathfinder '02 Firebird Trans Am. '88 K5 Blazer |
I had the same problem with my 76 stepside. The passenger side was the bigger problem. I had a buddy who does exhaust cut the collector flange back about 3 inches and used U-bends to go under the x-member and connect to my existing new 2/1/2" exhaust. The head pipes hang lower than the headers, maybe if I change to a dual hump x-member I can get the pipes up higher.
My 1st ![]() Owned: 76 chevy suburban 85 chevy K1500 90 chevy C1500 90 chevy K1500 sub 97 chevy C3500 crewcab dually 2000 chevy C3500 crewcab dually ![]() |
#8 | |
Surly*Speed*Demon
