Old 04-03-2005, 11:22 AM   #1
stan79chevy
stan79chevy's Avatar
205 front out put ??
my 205 has a 10 splined front yoke outout i want to turn it into one of the flange types. all of the flange type ones i can find seem to be fine splined. do they make a 10 spline flange style and does anyone have one. i want to use that style because i have a few of the cv flange driveshafts that i could use to save money.
thanks
stan
79 chevy k20 350/350/205/D44/14bFF
4.56 gears rock
LWB pimer black
01 S-10 ZR2 extended cab
4.3/4L60E/233
3.73 gear 31" DICK CEPEK CRUSHERS
stan79chevy is offline   Reply With Quote
Old 04-03-2005, 12:35 PM   #2
leadfoot067
horsepower junkie
your out of luck on that one....the only way to get flange front output is to change to a 30 spline or 32 spline output...its a relatively simple swap with the case in the truck....easier yet with the case out....heres a link to a place you can get new outputs and parts for a good price and good customer service...http://www.northwestfab.com/
67 short wide box,350/700r4/3.73posi
71 olds cutlass "S" mom bought new..12.30s@113MPH
leadfoot067 is offline   Reply With Quote
Old 04-04-2005, 12:41 AM   #3
1FaastC10
1FaastC10's Avatar
www.highangledriveline.com the best in the business, period.
1FaastC10 is offline   Reply With Quote
Old 04-05-2005, 07:21 PM   #4
stan79chevy
i have a 205 in my garage that has the flange i need
its the 30 spline type shaft. it is for a manual tranny though. will that matter? how hard is it going to be to take the shaft out of that one and put in mine? it sounds like i could do it and not have to spend anything! which is exactly what im looking for. Know of any sites or a place where i can get directions?
thanks
stan
4.56 gears rock
LWB pimer black
4.3/4L60E/233
Old 04-06-2005, 12:03 AM   #5
leadfoot067
horsepower junkie
yes you can swap the shafts...and you can do it with the case still in the truck..i havent personally done it..but a couple of buddys of mine have...they say it isnt really hard...if i was you ide take apart the one on the floor then youll know how it goes...
Old 04-06-2005, 06:01 PM   #6
stan79chevy
i did the one of the floor
i got it out. but needle bearing thing fell apart. there are tiny little pill like bearings everywhere in there. ill take the one out of my truck tomorow. but when i go to put the other one back in how do i get all them little bearings to stay in there?
stan
4.56 gears rock
LWB pimer black
4.3/4L60E/233
Old 04-07-2005, 12:51 AM   #7
leadfoot067
horsepower junkie
clean and dry them and pack them in with vaseline....that will hold them...
Old 04-08-2005, 11:18 PM   #8
leadfoot067
horsepower junkie
well did you win??? did it work???
Old 04-09-2005, 12:59 PM   #9
stan79chevy
i havent gotten to it yet
all i have done so far is get the shaft i need out of the parts case and got my truck into the garage. i dont think it will be much of a problem its actually not as complicated as i thought it was going to be. im going to take the whole transmission/tcase out and reseal around the adapter where it has been leaking. i also need to fix the speedo cable from leaking. ill take some pictures so that incase someone else is doing it it may help them.
thanks
stan
4.56 gears rock
LWB pimer black
4.3/4L60E/233
