Old 04-03-2005, 12:41 PM   #1
Goplay2
pic needed of emergency brake cable & bracket
need pic of emergency brake cable & bracket on 70' swb 4x4. the manual does not show the two brackets and the cable rod.
Goplay2 is offline   Reply With Quote
Old 04-03-2005, 11:50 PM   #2
aztec
help
can any one get me a pic
aztec is offline   Reply With Quote
Old 04-04-2005, 06:47 PM   #3
Goplay2
can some please help out on this, thanks
Old 04-05-2005, 11:45 PM   #4
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Here's the drums from my 71,4x4 blazer.
I can post a full size pic if you need to see it in greater detail.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 04-06-2005, 07:22 PM   #5
JimKshortstep4x4
Talking
I mocked up the e-brake cables on a Blazer frame so as to get a picture of them. Taking a picture under my shortstep 4x4 is useless as there is too much in the way.
I sprayed the brake parts white so they would show against the leaves as everything is brown rust on the frame. It should give you a good idea. There is a spring, (not pictured) that connects from the end of the front cable to the body to retract the cable. (Two WD have the spring made onto the cable). The connectors from the intermediate cable to the rear cables are not shown.
Good luck!
Jim
Old 04-07-2005, 09:03 AM   #6
Goplay2
thanks
i didnt know if the brackets were on top of the frame or under. and if i was missing something. i seen the book show a spring but this is what i have that came off the truck, thanks again for your help..
Old 04-07-2005, 10:07 AM   #7
JimKshortstep4x4
Goplay2,
Your frame is looking great. Nice work!
Jim
Old 04-07-2005, 11:15 PM   #8
Goplay2
thanks
jim i should post a pic.
