06-07-2002, 08:21 PM | #1 |
Seņor Member
Rocker replacing... yikes!
I've given up on the International Brotherhood of Overpriced Bodymen and have decided to tackle rockers and cab corners on my own. What's the worst that could happen... I spend many many hours on it, screw it up, and have to pay somebody else double to do what I should have had them do the first time?
So... I just pulled the passenger rocker off to survey the job, and so far it seems fairly straightforward. Any suggestions from you seasoned rocker-replacers out there??? Here's some preliminary pics... Rocker off. Hey, nice rust! Quick test fit. It fits great... no 20# intimidator required. I hope this is a good sign. Kenneth
06-07-2002, 10:08 PM | #2 |
I replaced my own rockers. Am I totally happy. No really. But it looks better than this!!!!!
06-07-2002, 10:18 PM | #3 |
aka Crusher, Crushergmc
Treat all the rust with POR-15 or something. I'd be wary of that inner rocker and just replace it too. They are easier because you don't have to make it pretty. Also, tack it in then test fit your door to make sure your straight. Good Luck and way to go.
"KEEP IT DOWN!" 70 Jimmy 454 2wd 56 GMC Big Window "It's funny till someone gets hurt, then it's freakin' hilarious" |
06-07-2002, 11:05 PM | #4 |
Put the door back on and adjust the door and rocker to where they fit. I repeat put the door back on and adjust the door and rocker to where they fit. I could repeat it again but you get the point. Tack weld the rocker and take the door back off it you must. I adjusted my rocker up and down but did not have it our far enough on the front where it matches to both the front fender and the door. Now I can't line the door and the front fender with the rocker like I would like to.
06-07-2002, 11:42 PM | #5 |
Don't just treat that rust on the rocker inner.....Sandblast it. It's tough to protect the rest of the truck interior from the sand but if you are looking for a repair that lasts you should blast, repair any perforations or just replace, treat with a phosphoric acid treatment and protect with zinc based weld through coating before closing the area in with the rocker.
Saskatoon, Saskatchewan Canada |
06-07-2002, 11:56 PM | #6 |
Saving 1 truck at a time!
You mean there was supposed to be a part in there? I guess they fell of my truck so long ago that I thought that was the natural look....LMAO! What gauge rocker did you get and who mfg. it? How do you like the fit-up?
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
06-08-2002, 11:06 AM | #7 | |
Seņor Member
And... for all you Eastwood stockholders, how much POR-15 do I need to order (figure me doing both rockers the same way)??? Also, I just got their new catalog in the mail yesterday and I don't see POR-15 anywhere... the "rust inhibitor" stuff they have listed is called "Rust Encapsulator." They also have a 'wash' type product called "Oxisolv." Do I need that? Thanks, Kenneth
06-08-2002, 11:54 AM | #8 |
Seņor Member
Aha! I've seen the light... POR-15 isn't from Eastwood. Thanks to Paul for the link!
Kenneth
06-08-2002, 07:29 PM | #9 |
I am a Referee of life.
rcdvl, you didn't replace rockers, you just installed some.Replacing means you had some to start with.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
06-08-2002, 10:20 PM | #10 |
Yes I did have some to start with. And I do not have a starting pic though. But that passenger side did not have much to start with.
06-09-2002, 07:39 AM | #11 |
1969 Custom 30 wrecker
This probably isn't ethical but I left the inners the heck out of there on mine! Those are the reason there was rust in this area to begin with. They would trap all the mud and moisture in there.
I found that mine are really strong even without the inners. You can jump up and down on them and they don't even move. I had intentions of installing the inners later but decided to leave it as is. The best way to deal with rust is to cut it all out. My rockers were worse than the pics above (driver side wasn't even there anymore) and my first ever rocker replacement went fantastic. I had to replace the outer floor area too, that's how bad mine were.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
06-09-2002, 09:03 AM | #12 | |
Seņor Member
Anyone else out there left the inner rockers out? Kenneth
06-09-2002, 09:30 AM | #13 |
Just playing with my scanner. Here's how mine turned out.
I replaced the whole driver floor, outer floor to rocker, and rocker on this side. No rust was left behind so this should last a very long time.
06-09-2002, 10:06 AM | #14 |
Bob, that looks really nice!!
06-09-2002, 11:14 AM | #15 | |
Seņor Member
Starting from: Pottsville, PA Arriving at: Walpole, MA 02081 Distance: 340.9 miles Approximate Travel Time: 8 hours 16 mins I've got beer Kenneth
06-09-2002, 12:19 PM | #16 |
LMAO!
Egads! I have enough of my own to do. 2 old trucks and 4 old cars keep me very active. Besides, I quit drinking 5 years ago. LOL
06-09-2002, 12:21 PM | #17 | |
Seņor Member
Kenneth
