Oh,you can't buy that new
![]() Join Date: Apr 2000
What spark plug wires fit best with Headers & SBC
I think the Taylors with 135* angle look the most universal. ??
of course i know all headers are made slightly different and at first i am running a cheap set of Dynomax that I repainted. thanx , DAVE
"been there, done that, ruined the T-shirt". 2007 LBZ GMC Sierra, ECSB 2006 LM7 RCSB Silverado 98 Vortec project. 94,3500,6.5L 4L80 81 SWB GMC POS finally gone ![]() 73 Pinto, stock, w/CragarSS's-eww ![]() LOTS of Cummins trucks. |
Professional Grade
I'd had no problems with just regular spark plug cables. Only one is a bit closer than I like, but if I went with any type of cable it'd have the same problem, the tube goes like right beside the plug, Its a tight squeeze getting a socket over the plug to take it out.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) Last edited by Russell; 04-03-2005 at 06:37 PM. |
Chevys Kick A$$
Yeah, I have just regular spark plug wires and there is a couple that are tight but not to tight other then that no problems yet.
-Later
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold ![]() -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
I'm not sweating the plugs too much I know how to get to them but i need some High perf wires. DAVE
Parts and more parts
I have used both the Taylor wires with 90 degree caps and MSD wires with the 90 degree caps. I use the ACCEL plugs, because they are shorter in the porcelein and this allows for more clearance around the #6 cylinder. I routed my wires along the side of the valve covers using a PROFORM wire loom and then had the wires drop down at each plug. It is clean simple and can be pulled easily to allow for plug replacement.
which of those proform looms did you use, thanx , DAVE
Go to Pace Performance ( www.paceparts.com ) and search for wire looms.The ones that I use are like the ones that have the Chevy emblem on them, but mine do not have emblems, just a polished aluminum finish.
Details 66261 - SBC Linear CHROME Wire Looms PACE Price $45.12 Details 141638 - SBC Bow Tie Linear Wire Looms. fits 1986 and prior. PACE Price $59.06 Last edited by piecesparts; 04-03-2005 at 11:55 PM. |
