04-03-2005, 07:31 PM | #1 |
Started On My Disk Brakes Today
I STARTED INSTALLING MY DISK BRAKES TODAY. I GOT ALMOST EVERTHING IN PLACE. I DID NOT KNOW IF IT WAS GOING TO WORK. NO PROBLEMS SO FAR. I NEED TO MAKE MY FINAL CALIPER BRACKETS NEXT WEEK.
04-03-2005, 08:22 PM | #2 |
Details! We need details on componets.Looks great!!
69 Lwb C-10 402/700R4 70 Lwb C-10 250/3pd Wisc. |
04-03-2005, 08:27 PM | #3 | |
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
04-03-2005, 08:34 PM | #4 |
PROJECT 7DEUCE
Maybe you could do a write up on it and put it in the faq part of the board.. Looking great keep us posted...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
04-03-2005, 10:16 PM | #5 |
I'M USING 94 CAPRICE ROTERS. 96 CAMARO REAR CALIPERS. I MAKING THE CALIPER BRACKETS. THE MASTER IS FROM A 70 CORVETTE AND THE A VALVE IS A DISK DISK VALVE. I USED A SIMILER SET UP ON MY OTHER TRUCK BUT I USED A CAPRICE CALIPER. IT IS WORKING WELL. THIS IS MY OTHER TRUCK.
04-07-2005, 11:07 PM | #6 |
Back On The Road Today
04-07-2005, 11:47 PM | #7 |
Questionable
So - you manufactured your own caliper bracket? How thick of a gauge of steel did you use?
So....using the Camaro and Caprice, this leaves you with 14mm wheel studs, right? Dude, that is so sweet. I can't wait to do my truck! What was the cost on the hardware?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
04-08-2005, 02:23 AM | #8 |
Yeh It's Fast
Wow
Wow Great job pls give us more info
(I'm sorry if the spelling isn't correct,i'm trying the best I can ) 1972 C20 3/4 Pickup Fleetside 502ci Th400 Click here to view pictures of my truck 1971 C20 3/4 Pickup Fleetside 350ci 3speed manual gearbox "IF IT AIN'T BROKE DON'T TRY TO FIX IT" Zwijndrecht, The Netherlands Europe |
04-08-2005, 09:16 AM | #9 |
blood type; Retumbo
what did you use for park brake cables? Camaro? Caprice?
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
04-08-2005, 09:59 AM | #10 |
Livin' it up.
as an FYI i'd be a bit leary of the parking brake... integral parking brake units typically dont hold too hot on trucks.... hence why most dont use them and use a drum in hat system instead. There are some exceptions (H1) but most cars get IPB and even those systems are typically just above passing for hill holds..
-Greg; Sold the 69 C20. It's off to a better home with more love! Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires. |
04-08-2005, 11:32 AM | #11 |
Just Don't Stop!
Yeah I'd be interested to hear about the PB. I bought some 78 Eldorado calipers to use on the rear. They are supposedly the best as far as the IPB's go.
1968 C10 build in process TT LSA/6L90e/9" |
04-08-2005, 09:24 PM | #12 |
Looks Good! I did something similar with the Caprice/Impala caliper and rotor.
04-08-2005, 11:22 PM | #13 |
ON THE PARKING BRAKE I USED THE STOCK CAMARO CABLE
04-09-2005, 01:08 AM | #14 |
Professional Grade
Let us know how well this works on the truck. Such as emergency stopping abilities when it is rainy out etc. I'd be a bit worried about the rear end whipping around on me when I slammed on the brakes and locked up the rear.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
04-09-2005, 11:11 AM | #15 |
So Far So Good Th E-brake Holds The Truck No Lock Up Problems. I Need To Change The Cable Angle At The Control Arm. I Drove In The Rain Last Night With No Lock Up Problems. I Think I Am Going To Change The Booster It Seems To Need More Boost Possibly Due To The Volume Increase In The Rear.
04-10-2005, 12:02 AM | #16 |
I'd sure like to see the bracket that you used. Can you post a template?
Present: 2015 Tacoma. Yeah, not a GM, but I love it. 1969 GMC 32,000 - fix, drive, relax, fix... 2019 BMW R1250 GSA - Yahoooooooo 1979 Honda GL 1000 - retro touring at its best. Past: '05 Sierra 4x4 - Had 270,000 KM and running well when it was written-off by a stop sign runner. '94 F-150 from the "F word" company. I'll admit it...good truck. Sold what was left of it for $800 to a guy who came to pick it up at 11:00 PM with cash in hand. Hmm. '79 Sierra Grande (Black) organ donor - perfect rebuildable 4-bolt 350 and a good TH350. '76 Sierra Grande (Orange) - hate isn't too strong a word. Kid who bought it turned it into a hot rod. '68 C-10 R.I.P. - Dad's old truck...too far gone to resurrect. '59 C-50 - with hoist. Truck is gone, wife isn't. Nuff said. |
04-10-2005, 08:28 PM | #17 |
HERE ARE MY TEMPLETS FOR BOTH CAMARO AND CAPRICE CALIPERS. BOTH USE THE CAPRICE ROTER.
