Old 06-07-2002, 09:09 PM   #1
colohusker
Rear Drums
Okay, went to bleed the brakes since I had very little pedal, and mushy at that. Broke the bleeder screw off on a rear drum since it was rusted on there. Took the wheels off, trying to get the drums off to replace the wheel cylinders, and the #$!@ drums won't come off.
Anyone have any special tricks to get drums off? It's on a '71 1/2 ton, don't know the axle right off hand, but it's the original one. I punched out the adjusting hole, seems that the springs and self adjuster are laying in the bottom of the drum, and the shoes are floating loose. I can flex the outside rim of the drums forward, and see the drum move on the lug studs, but the center is stuck and won't move.
Any suggestion short of a nuclear device will be considered!
Scott
I say it's only money, my wife says it's only a truck....
'71 C10 Deluxe, factory ac, ps, pb, should be done by 2102
Longmont, CO
husker95@hotmail.com
colohusker is offline   Reply With Quote
Old 06-07-2002, 10:05 PM   #2
Mike C
Mike C's Avatar
As a last ditch effort, you can grind the tops off the pins that hold the pads to the backing plate. You can then pull the whole mess far enough out to get it apart. You'll have to go buy some new parts, though... If all of the adjuster parts have fallen out, sounds like you have major failure of something. I'd be hard pressed to believe it was hung up if the star wheel adjuster was gone. Check again.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-07-2002, 10:13 PM   #3
Gordo
Is it frozen to the axle? A couple of sharp, hard blows with a BFH on the outside edge usually breaks them loose, if not try some heat, then a BFH.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03)
1998 S10 short bed
2002 S10 Blazer
1942 Oldsmobile
1958 Massey Harris Pony
1951 Wife
Killingworth, Connecticut
May those who love us, love us, any of those who do not love us, may God turn their hearts.
And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping.
A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist.
Gordo is offline   Reply With Quote
Old 06-07-2002, 11:09 PM   #4
J
J's Avatar
I argee with Gordo. Happened to me once, I took a torch and heated it up (not too much) whacked it a few times, let it cool and whacked it again. came right off
'72 C-10
'99 Silverado
'91 S-Dime
J is offline   Reply With Quote
Old 06-07-2002, 11:17 PM   #5
racedvl
racedvl's Avatar
You are hung up on the shoes no doubt! If you can't loosen them do what Mike C said. Destroy the pins that hold the shoes to the backing plate.
racedvl is offline   Reply With Quote
Old 06-08-2002, 02:43 AM   #6
colohusker
Thanks for the suggestions! 30 minutes of torch work per wheel, and 5-6 whacks with a 6lb sledge broke them free. On both wheels, had to replace the adjuster, springs, hold downs, shoes, and drums. It appears that one of the hold downs on each wheel either rusted away, or otherwise disappeared, freeing the shoe, adjuster, etc. to fall down and get ground up against the drum.
Tomorrow I get to see what's wrong with the front, thank god their discs! Figure replace caliper, piston, rotor and pads and I might actually be able to stop!
Once again, thanks for the suggestions!
Scott
Longmont, CO
