Old 04-03-2005, 10:59 PM   #1
bigarmzz
bigarmzz's Avatar
what is needed to fit a blazer rear bumper on a 87 2wd?
i'm wanting to do away with the big ol rear step bumper on my 87 2wd, as i'm lowering it and the step wont look right....
i'm wanting to put on the blazer style rear bumper (the one that sits somewhat flush to the body)
what am i going to need to do this?...i'm pretty sure the step bumper brackets are different than the blazer style....
..i know alot of the 81-87's came this way
1987 350 TBI lowered 5/7
bigarmzz is offline   Reply With Quote
Old 04-04-2005, 12:16 AM   #2
72 CustomCamper
huh ???
72 CustomCamper's Avatar
PM sent
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 04-04-2005, 04:25 AM   #3
Jonboy
Slots go on anything!
You should just need the center brackets. I am pretty sure the braces on the burb/blazer bumper will work.
1974 Jimmy- 5.3/4L80e/NP241
Old 04-05-2005, 12:16 AM   #4
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
You will need the center braces that mount to the frame. The step bumper pieces are different. Depending on the step bumper, sometimes none of the brackets will work.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 04-05-2005, 12:44 PM   #5
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Are those needed brackets unique to the pickup, or can the bumper be mounted using Blazer or Suburban brackets?
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 04-05-2005, 03:47 PM   #6
Jonboy
the center brackets are made to the rear of the suburban and blazer frames. The end of the rails are cut off, so to speak, on a pickup. The center brackets bolt to the rails on a pickup, similar to how an aftermarket bumper would. There is a pretty good illustration in the LMC catalog of the brackets.
Old 04-05-2005, 06:45 PM   #7
Captkaos
Captkaos's Avatar
Ditto on what JonBoy said. Blazer/Burbs don't actually have center brackets as they are made into the frame.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
