Old 04-04-2005, 03:38 AM   #1
Laoich
Truck wiggles?
I know they're big, and I know older cars will have speeds where they wobble a bit, but how bad, and should it happen at 55, and then 75 mph only? It's not bad, just curious. I am in need of an alignment though, I figure. Will that fix it?
87' GMC R2500 Sierra Classic Suburban - 454
Laoich is offline   Reply With Quote
Old 04-04-2005, 10:06 AM   #2
screwballl
Tonawanda 454
screwballl's Avatar
sometimes.... it can be a combinations of things or one specific thing including:
tires, shocks, alignment, bearings, brakes, something in the steering (column, control box, steering arm), U-joint on drive shaft, plus numerous other things...
if you know you need an alignment anyways get that done then have it checked piece by piece
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!!
04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011)
In the past 30 years about 90% of Fords are still on the road, the other 10% made it home.
screwballl is offline   Reply With Quote
Old 04-04-2005, 08:26 PM   #3
bumpsburb
87 suburban "Jack"
my 87 had a wiggle and the steering seemed lose. I had the front end aligned and... it was gone. I asked what parts they replaced and he said in these big trucks sometimes it just needs to be tightened up and aligned because the tired flex so much.
Only cost me a front end alignment I think it was less than $45.00
Hope that helps
Scott
Damn Skippy
bumpsburb is offline   Reply With Quote
