Old 04-04-2005, 10:18 AM   #1
TruckinDaddy
What's that funky smell?
TruckinDaddy's Avatar
Spark plug problem
I was pulling the plugs yesterday to replace them and to put on new wires. The plugs are really rusty on the outside. All of them came out without a problem, except #6!
When I backed it out, the "plug seat" came out too. It looks pretty rusty, too. Now I am wondering if I should just replace all of these, when I install new plugs. Will it be OK to reinstall this one and then new plugs?
And if you really want to help a new brother out, what is this "plug seat" actually named. I searched the manuals I have and could not get a good answer.
looks like I have a pic problem. I'll correct ASAP
Pics are down in post # 6!
Mike S
68 C10 Long Step (Pretending to be a Long Fleetside) Grandpa's Farm Truck
3 on the tree, 307, No power brakes or steering
Factory Options - HD rear spring and Ammeter/Oil Gauges
My truck blog
My Car Domain page
TruckinDaddy is offline   Reply With Quote
Old 04-04-2005, 10:33 AM   #2
jhow66
jhow66's Avatar
Are you talking about the spark plug gasket (looks like a washer)? If so the new plugs will come with them. Be sure all the old ones are removed.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 04-04-2005, 10:36 AM   #3
jhow66
jhow66's Avatar
UPDATE: I bet you have what are called "nonfoulers". It screws into the plug hole 1st then the plug. This is to keep oil from fouling the plugs.
Old 04-04-2005, 10:39 AM   #4
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
pic
sneakysnake is offline   Reply With Quote
Old 04-04-2005, 10:40 AM   #5
TruckinDaddy
I tried to post a pic. I'll try again later.
It is not the gasket. It was the metal part that the plug actually bolts into. and then this part bolts into the block. This plug and "seat" were so rusted, that it just pulled out with the plug.
Sorry my descriptions stink. Really new at all of this.
Mike S
My truck blog
My Car Domain page
Old 04-04-2005, 10:53 AM   #6
TruckinDaddy
Sorry the pics took a while. Thanks for the info so far, guys.
Mike S
My truck blog
My Car Domain page
Old 04-04-2005, 11:16 AM   #7
sneakysnake
thats a "fouler"
It spaces the plugs back so oil doesnt get to them.
Old 04-04-2005, 11:27 AM   #8
sneakysnake
http://images.google.com/images?q=sp...=Google+Search
Old 04-04-2005, 12:01 PM   #9
TruckinDaddy
Originally Posted by sneakysnake
thats a "fouler"
You guys are awesome!
So, good idea to replace, bad idea, or does it matter?
Mike S
My truck blog
My Car Domain page
Old 04-04-2005, 12:04 PM   #10
sneakysnake
If the motor uses oil they will make the plugs last longer.
Old 04-04-2005, 12:17 PM   #11
TruckinDaddy
sneaky -
Thanks for the great info. I am trying to get this truck running after it sat in a pasture for 10 years or more. I assume since it had at least this one non fouler on it, that it was burning some oil.
But I am thinking that maybe I'll go without when I install new plugs and wires. I am hoping that then I can see for myself how much oil it burn and how long the plugs last. For all I know, these might be the original plugs. The truck only had 45K on it when it was put out to pasture.
I appreciate all of the help.
Mike S
My truck blog
My Car Domain page
Old 04-04-2005, 08:55 PM   #12
rmrtndl
Hey ya'll, Watch this!
rmrtndl's Avatar
Hey Mike,
Never seen a non fouler before.
Any luck with the carb leak?
Rick M.
72 GMC SWB Fleetside
25 Chevrolet Superior Series Truck
95 Mazda Miata
06 Dodge Charger RT
http://ram92.ods.org/blog.html
rmrtndl is offline   Reply With Quote
Old 04-04-2005, 09:50 PM   #13
TruckinDaddy
I made it leak A LOT worse. That is something, right?
I am just going to get a re man unit soon for it. But it was pretty cool to get inside of.
Mike S
My truck blog
My Car Domain page
Old 04-04-2005, 10:11 PM   #14
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
Haven't seen a fouler in a long time.
Good luck with the fireup.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 04-04-2005, 11:19 PM   #15
CHEVIBUBBA
got boost?
CHEVIBUBBA's Avatar
i would not reinstal the foulers.
they are a band aid.
with 45k original miles the engine shouldn't be burning oil unless it's the original oil.
once you get a few hundred miles on it, if it is burning oil,(blue smoke),while your at a steady state cruise or heavy part throttle/w.o.t. plan on a ring job.
if it just blows a bit of blue smoke on startup, it's worn valve guides.plan on a head job.
'70 chevy lwb w/'67 hood.
357 s.b.c. built, 4l60 w/vigilante lockup high stall converter, edelbrock pro-flo,brodix heads,comp cams rollerized w/ belt drive, one piece d-shaft, yada, yada, yada.....
'82 honda v45 sabre"the black"
CHEVIBUBBA is offline   Reply With Quote
Old 04-04-2005, 11:53 PM   #16
TruckinDaddy
Good info, thanks Chevibubba
Mike S
My truck blog
My Car Domain page
Old 04-05-2005, 11:36 PM   #17
CHEVIBUBBA
got boost?
CHEVIBUBBA's Avatar
i'm here to help!
