Old 04-04-2005, 10:52 AM   #1
fade94
fade94's Avatar
Factory sway bar.
I am converting a 69 Short step into a 67 short fleet. I got a lot of work done Sunday and discovered a factory sway bar. My question regards the brackets. The front brackets appear to be damaged from curbs or what ever. Can they be fixed? If not, where can I get new ones? I have only received one catalog that I have ordered and they don't show to have the part available (LMC).
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates)
67 short step project (will get SWB from the 68)
67 Camaro, #'s matching (my wife's)
03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear
fade94 is offline   Reply With Quote
Old 04-04-2005, 11:19 AM   #2
smbrouss70
smbrouss70's Avatar
Early Classic has them. If you're going to be lowering your truck, they also have the bracket for lowered trucks that tucks the sway bar up a little closer to the frame.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 04-04-2005, 11:22 AM   #3
smbrouss70
smbrouss70's Avatar
Also, If your converting your stepside into a fleetside, what are you going to do with your step bed? I may be interested in it, if you're getting rid of it and it is in decent condition.
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
