Old 04-04-2005, 01:42 PM   #1
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Yoke needed for TH350C
I have the transmission out of my truck for a rebuild. While replacing the u-joints, I found out that the yoke that goes into the tail of my TH350C is grooved. Does anyone know of a source for a new one?
The dealer says the part is discontinued. A driveshaft place around here wants $60 for a new one. Anyone know of a cheaper source? It is the one with the vent hole in it, and it uses the inner clips.
Thanks,
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 04-04-2005, 08:12 PM   #2
Slonaker
Slonaker's Avatar
Bump for the evening crowd...
Stock '01 Silverado
Old 04-08-2005, 01:17 PM   #3
Slonaker
Slonaker's Avatar
Last bump.
Stock '01 Silverado
Old 04-08-2005, 01:58 PM   #4
mudgutsandglory
Certified Truck Nut
mudgutsandglory's Avatar
they take a standard TH350 yoke as far as i know, shouldnt be hard to find one
later
Dan
1982 GMC Sierra Classic 1500 Longbed
350, TH350, 3.73 10 bolt
soon to be slammed
mudgutsandglory is offline   Reply With Quote
Old 04-08-2005, 06:08 PM   #5
Slonaker
Slonaker's Avatar
Originally Posted by Riptide's 78p/u
i believe there is a "sleeve" that u can get for it...like the ones they make for harmonic balencers
None of the auto parts stores have any idea what I'm talking about. They say they can't get a yoke or a sleeve. An acquaintance with a front end shop says the sleeves are available, but that they cost $20 and have to be pressed on.
I can get a new yoke from a driveshaft place locally for $60, but I was hoping there would be something available cheaper by mail order.
Slonaker (cheap b@st@rd)
Stock '01 Silverado
Old 04-10-2005, 08:16 AM   #6
tphsmith
still buypickupparts
tphsmith's Avatar
the Yoke
I have a 81 drive shaft off a th350c in my garage right now, and the tranny is in the dumpster, Im not sure what your needing can you clearify for me I bet I can help you out. if you want the yoke you can have it jus pay for the ride. the U joints are the type with clips on the outside of the u-joint caps for retainer.
Its Gonna be a Great Day, I woke up this Morning.
72 SWB Fleetside freshly painted. putting a 94 LT1 with
700R4 tranny lowered 4 in the front 6 in the back
81 chevy half ton 350
89 Silverado 4x4 going ta church truck
tphsmith is offline   Reply With Quote
Old 04-12-2005, 10:22 AM   #7
Slonaker
Slonaker's Avatar
I apologize...I just saw your post. I need the yoke that goes into the back of the transmission. Mine has a groove where the seal rides on it. Unfortunately mine uses the inner clips to retain the u-joint, and I just replaced it with a new u-joint.
I really appreciate the offer.
Slonaker
Stock '01 Silverado
