tonneau cover????
hey, i need a tonneau cover to cover my new bedwood. i dont really want to drill holes, and i want a vynal one, not a fiberglass or plastic ones. any advice, which are good, which are bad, which ones leak, and so on. ANY advice or suggestions are appreciated! thanks a lot, Ben
Brandon, SD 69 GMC 1/2 ton 2wd wide long bed with wood 3 on the tree 350 engine 4 bolt main rv cam AIM = Alphray04 |
Got 20's????
If you come to the brookings car show I will show you mine. It is an Access cover. Its vinyl and is made locally. You will have to buy it for a 73-87 chevy pu and notch the rear of the rails to fit your truck. Thats what I had to do. I will e-mail you pics of the notching if you want or just check it out on Sunday.
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged 02 Sierra Ex-Cab 4wd 2500 HD The 72 went down the road. |
I know you said you didn't want a fiberglass one but I really really like my checkmate flush fit cover. Only gotta drill a few small holes. Check them out, trust me! www.checkerpro.com
My 2 cents
'72 C-10 '99 Silverado '91 S-Dime |
cool
the checkmate ones arent too expensive, i like the flush fit thing too. got any pictures of it on your pickup?
72chevylwb, hopefully i will be to brookings and will check it out. anybody else have pics of covers, or good or bad experiences with them.. thanks, Ben
anybody have problems with certain covers, or good luck with other brands? THANKS, Ben
I have one of the checkmate vinyl covers. fit flush with top aluminum frame, clamp on no holes to drill. I think it was around $165
atheystruck@comcast.net 67 1/2 ton 4wd custom cab 72 1/2 ton 4wd super cheyenne 71 1/2 BB super cheyenne shortbed |
I don't got a pic but mine is a hard checkmate cover. Cost about $400 plus shipping looks nice and locks up. One of the best thigs I have done to my truck.
400 is a lot for my budget, then id need to get it painted. PICKUPMAN- how do you like the 165 dollar vynal checkmate cover. i like the flush fit ones. does it seal ok? is it hinged? can you lock it? thanks a lot, Ben
i would like some more information about different brands before i order one. thanks a lot! Ben
I like the cover. It doesn't stick up or anything. From the side view you can't hardly tell it is on there. It seems to seal pretty good, but the only time my truck usually sees water is when it is washed. Don't drive it too often in the rain, unless I get caught out in it. Too much detailing to do under neath. It is stationary it does not hinge up, but I think you can buy the hinge kit. Then you have to drill your bed. Bill
pickupman- so how do you get in it like if you need to put something in your box? i probably wont, im spending too much time on my wood, and with my nice new paint in my box, but would i if i ever needed to haul somthing big?? snaps, velcro,??
anybody ever get the one from lmc?? thats pretty cheap. thanks a lot, Ben
It is pretty much a staionary unit. only way it comes off is by the 4 c-clamps style clamps. You can still operate the tailgate as far as getting into the bed.
#13 |
oh, ok. thanks, i think i might just order the hinged flush mount vynal one from checkmate. it looks good. thanks a lot, Ben
#14 |
does anyone have the contact info for checkmate ?i like to put a cover on my 69 longbed.thanks
70 c10 stepside ,350v8, m-20 4 speed ![]() |
#15 |
Back in the sticks
I will send you the company name on mine tonight. It was only $180 and there are no holes to drill. The frame c-clamps to the bed sides and the cover snaps to it. Comes with weather stripping to seal the rails to the bed top. I think its finish line out of Indiana. I'll get the info tonight though. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
#16 |
Slowly getting CRSS...
red71cheyenne,
could you send me the info also im gonna get a vinyl cover but i wanted one i could unsnap to get into, thanks. -Nic
-Nic Lutz, Fl My Team Website The Heavy Chevy Website ------------------
There is No replacement for Displacement... "If everything seems under control, you're just not going fast enough." - Mario Andretti |
#17 |
Back in the sticks
Sure no problem. I'll get the brochure out tonight. Jeff.
#18 |
I have a vinyl cover that I took off of a 72 K20 that I would love to sell. It is a very dark blue and it is for a long bed. It has the aluminum frame with no holes required. Love for it to find a new home cause it is always in my way. Located in Cincinnati Ohio if anyone is looking for one.
#19 |
Back in the sticks
Ok. I was wrong about the name. Its an INDY ORIGINALS. Their number is 1-800-987-4639 and they are out of Indianapolis like I said. They had covers for all years, long or short bed. Give them a call and see if you like it. I really like mine. Jeff.
#20 |
I have a Lund tonneau cover on my truck. I bought it through LMC although I'm sure you could get it elsewhere. I like it, its also super easy to install with no holes to drill. It has black vinyl cover with snaps that hold it down, these are easy to snap off and roll it back. I believe i paid around 300 but you might be able to bring the price down if you didn't go through LMC.
1970 Custom Camper 402BB W/TH400 Factory Tach, AC, wood bed, Tool Box, rear leaf springs (in restoration) |
