Questionable
Where to buy this connector?
I would like to replace my old ignition wire at the firewall bulkhead/block with a new one. I'd like to replace it with a new connector instead of bending out the new one. This one won't fit very well around the 12-gauge stranded wire I'm using and I don't want to solder it.
Anyone know where a person could find this exact connector locally?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 04-04-2005 at 09:34 PM. |
try napa or carquest ,i forget which one i went to when i needed one for my hei
Questionable
Really? I'll swing by NAPA in the morning. Not sure where any local CarQuests are.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
Professional Grade
When I got into the connector situation when doing my TPI, I simply cut the wire that was already on the connector off about a half inch back, stripped all of the insulation off, then pushed the new heavy gauge wire overtop of the thinner wire & soldered it like that. I then put some small shrink wrap overtop of the whole connector, and voila, I had my heavier gauge connector
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
MAD has those if you can't find them locally. Also if you are going to be running enuogh current through that to need 12gauge wire it should be soldered.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
![]() Join Date: Aug 2001
I GET THOSE AT MY LOCAL TRUE VALUE COAST TO COAST HARDWARE. THEY'RE KINDA SPENDY, LIKE A BUCK A PIECE. THEY COME 3 IN A PACK. LET ME KNOW IF YOU CAN'T FIND ANY, & I'LL GET YOU SOME. I'M SURE THESE CAN GO IN A 37 CENT ENVELOPE. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
blood type; Retumbo
I have about 50 of these in my electrical service cart at work. how many do you want? FREE!
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
Lovin' Life in Miss.!
Napa #
The truck... you hear that? No really, you did hear that?!!! |
Glowing since 1978
Chickenwing your the man. I was going to say a NAPA and they were called Packard connectors but I can't beat your detailed information.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in 71 Corvette Coupe 454 4 speed 69 Chevy C20 Custom Camper |
I'm still looking for them in 10-12 gauge...
The truck... you hear that? No really, you did hear that?!!! Last edited by chickenwing; 04-05-2005 at 09:34 AM. |
More Cowbell....
I also saw those at Autozone yesterday. But not sure of the intended wire gauge.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
The ones I saw at Autozone were pricey. They were 14-16.
#13 |
Chickenwing's got it right and I think they are part of the "Packard" system. Here's what I found on the American Autowire website www.americanautowire.com
The contacts for wire sizes 20-14 AWG are the "series 56" contacts (1/4") male part number - 500096 qty of 10 for $3 female part number - 500095 qty of 10 for $3 On the smaller wire gauges, strip 2X the normal length and fold the wire back on top of itself. I believe the 10-12 AWG contacts are "series 59" contacts (5/16") and are pretty tough to find. female part - 500186 qty of 10 for $3 male version - ??? anyone know??? I use a Radio Shack uninsulated terminal crimper that I modified to make it "thinner" so it would not bend the contact while crimping the wire portion. And always give it a good "pull test" after crimping to ensure the crimp is solid. Good Luck!
'56 F-100 (w/all GM stuff) Lookin' for another parts chaser! ![]() '05 GMC crew cab Last edited by fatfords; 04-05-2005 at 01:23 PM. |
#14 |
Thanks for the source! Added em to my favorites.
#15 |
Glad to help! If anyone knows where to get the "series 59" male contacts, I would love to have a source. I'm getting tired of re-using the old ones with solder and heat shrink.
Good Luck!
'56 F-100 (w/all GM stuff) Lookin' for another parts chaser! ![]() '05 GMC crew cab |
#16 |
Questionable
Got them at Napa today. THANKS!
