Old 04-05-2005, 06:26 AM   #1
willow72
willow72's Avatar
need eletrical help!
i have abattery drain i have done the volt meter between the neg. battery post and cable trick popping out one fuse at atime heck i popped out all the fuses at one time and still had power flow what is the next trick yall have up your sleeve i really need help! thanks for any help yall can give me ,john
willow72 is offline   Reply With Quote
Old 04-05-2005, 06:36 AM   #2
cdowns
cdowns's Avatar
try disconnecting the alt and see if that's where the problem is
Old 04-05-2005, 08:03 AM   #3
WRMZ71
Cause the Chicks DIG IT!!
WRMZ71's Avatar
what Cdowns said. If you pulled all your fuses then it has to be something that is hooked to the battery but not on a fused circuit.
WRMZ71 is offline   Reply With Quote
Old 04-05-2005, 08:46 AM   #4
RON WOODGEARD
Resident Young Old Dude !
You CAN'T use a Voltage meter.... You have to use a trouble light..a 12 Volt bulb......IT DIDN'T WORK FOR ME!
I just am completing putting everything back together from a week long testing session for the same reason.. In my case where I have added so much ( almost too much) aftermarket electrical stuff, it can take a very long tedious time to find the Culprit.. Mine was a few small things drawing just a little from each thing...Then again of you have basically everything electric Stock, it shouldn't be a big problem..
But drop the meter,, Pick up the 12 volt light tester..
RON WOODGEARD is offline   Reply With Quote
Old 04-05-2005, 01:19 PM   #5
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
A meter will read though the diods in the alternator,use a light
sneakysnake is offline   Reply With Quote
Old 04-05-2005, 05:59 PM   #6
willow72
willow72's Avatar
thanks guys yall are great,i will get a test light thanx again,john
