04-05-2005, 11:39 PM | #1 |
Little Hot, Sweating my @#$% off!
It's starting to get warm up in my part of the world and now I wish that I wouldnt have put a new blower and heater core in this winter. What can I do so that my truck doesnt allways blow hot air. It seems like whatever way I put the knobs on my non-ac truck it still blows hot, really hot air. Could I just take out a fuse or something, or disconect the lines that go to the air duct under the dash?
-Cory 1967 2 Wheel Chevy |
04-05-2005, 11:48 PM | #2 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
you could put a shut off valve inline in the hot coolant supply line.
I've seen plenty of guys just use a regular old garden hose tap.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
04-06-2005, 01:31 AM | #3 |
But wont that cut off the coolant flow? Maybe I'm just not understanding something here. Does anyone have a picture of the valve setup? I'd really appreciate the help.
04-06-2005, 03:46 AM | #4 |
Low & Slow
You could also re route your heater core hoses. run one from the two points on the engine that the hoses are currently connected to. then run the other hose from one end of the heater core to another. The valve is a better idea though, that way when it gets cool or your windows start to fog up you can just turn the valve open and go. The valve is supposed to cut off hot coolant from flowing into the heater core. It will not have a negitive effect on cooling. I do not have any pics though.
70' C-10 LWB Fleetside 4.5/6 drop Last edited by Hotrod70C10; 04-06-2005 at 03:47 AM. |
04-06-2005, 07:48 AM | #5 |
A/C trucks came from the factory with a vacuum operated cutoff valve.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
04-06-2005, 08:41 AM | #6 |
If you have a NAPA in your area, they should have valves that you can put in the heater hoses and stop coolant flow into the heater core.
I had to do this on my 78 vette to prevent the hot air flow in the summer.
ongoing 1970 c 10 lwb 1994 z-28 few mods.-owned since new 1978 vette silver/grey 25th anniv. paint |
04-06-2005, 10:04 AM | #7 |
Initially, I installed a new Heater Control Valve. Didn't help. So, I installed a ball valve in mine. No more hot air and, the a/c blows about 10° colder, too!
Good Luck! TP |
04-06-2005, 10:10 AM | #8 | |
Resident Curmudgeon
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
04-06-2005, 10:47 AM | #9 |
Hey, 1sttimepro71, how hot does it get in Minnesota?
If you desire the best heat our great county has to offer, come on down to MS in July or August, temp may only reach 95-98 degrees Farienheit. The humidity is the killer running from 75% well into the 90% numbers, very hot sweltering heat. Stand still and just sweat, sweat, sweat.
04-06-2005, 12:54 PM | #10 |
We had a couple of days last summer where the heat index was 110. Thats about the extreme. But the opposite of that extreme is easily -60 with windchill.
CPNE I'll try what you said, thanks for the reply's guys.
04-06-2005, 04:26 PM | #11 |
couldn't you just loop a hose from your water pump to the intake? that is only if yours is set up like this. Mine is on my 350 but that engine is from an 82 with a long water pump.
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
