Currently Blazerless
Complete 67-70 cruise control
Factory cruise for 67 to 70, everythings here except the brake light switch and it can still be bought new [about 15 bucks]. The broken cruise lever in pic is not included but has an NOS lever to go with it.
250.00 plus shipping ![]()
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
#2 | |||
Union Electrician
any trades?
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
![]() Join Date: Aug 2001
PM sent
So,is tilt different?Or doesn`t it matter?
PM Sent, Fern..
Young Gun wth Fast Inline
Does it still work? and is this the same thing that they used on the inline?
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!! |
Cruise is SOLD to Brewski*
My question still stands was cruise available on an inline and is the style the same or different?
Rod can probably answer your questions better than me, but I see no reason why it wouldn't work with a six, because the 68-70 cruise hooks to the throttle arm instead of the carb. Here is a pic of the clip attached to the arm just below the throttle rod that goes to the carb. I'm not sure if cruise ever came from the factory with a six cylinder though. There is no difference in tilt/non tilt setups that I know of.
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
I dont know if the six ever had one but I'm sure it could be made to work, you would have to fabricate a bracket to hold the vac pod is about all.
I believe the vacuum pod bolts to the firewall.
I was thinking it bolted to the motor but I think your right.
#13 |
just trying to get things straight. HuggerCST says 68-70 bolts to trottle, but Blazerman says this is for a 67-70. Whos right and what is different about the 67?
Thank you for the help
#14 |
Where are you Rod? LOL The reason I said 68-70 is because I'm thinking that cruise didn't come out until '68, but I could be wrong. From what I understand, Blazerman's cruise setup is the early style. There is not much difference in the early and late style,(pre '71), but the early style had 2 vacuum lines on the pod, and the servo is different in that the speedometer cables are 90 degrees from each other. I have both styles, and those are the only differences that I see. I would post more pics but they are on my computer at work. A while back Rod filled us in on cruise setups. I'll do a search and try to find it for you.
#15 |
Here it is. Alot of info here. http://67-72chevytrucks.com/vboard/s...cruise+control
