Old 04-06-2005, 03:47 PM   #1
402Bowtie
402Bowtie's Avatar
2wd and 4wd steering box differences???
NAPA shows that a power steering box for a 2wd is different than a 4wd. The only difference I can see between the two is that 4wd gear box is able to turn 1/8 of a turn more. What would happen if you mounted a 2wd gear box on to a 4wd truck? Anybody ever done this...any problems???
402Bowtie is offline   Reply With Quote
Old 04-06-2005, 04:29 PM   #2
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
I don't know about this year of 4x4,but the later ones the pitman shaft is different.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 04-06-2005, 05:12 PM   #3
1969K10
1969K10's Avatar
My 4X4 steering box, the arm moves front to back and contols the driverside tire, with a link to the pass. tire.
My 2X4 steering box, the arm moves left to right and controls the pass side tire, with a link to the drivers tire.
1969 K10 - V8, 465, 205, 12 bolt, D44 2002-current
1969 K20 - V8, 465, 221, Eaton, D44 2012-current
Nothin' but drums on all 4 corners!
past horses in the stable
72 C10-short step (97-02), 68 C10-long fleet (06-12)
1969K10 is offline   Reply With Quote
Old 04-06-2005, 05:21 PM   #4
Russell
Professional Grade
Russell's Avatar
The only difference I am aware of is the pitman arm, and how it is positioned.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 04-06-2005, 11:12 PM   #5
thisolechevy
cant you just change that positioning?? just wondering
Man I need another 67-72!!!
thisolechevy is offline   Reply With Quote
Old 04-07-2005, 01:45 PM   #6
1969K10
1969K10's Avatar
the steering boxes have splined hub that the arm attaches to. on that splined hub, there is a large spline. it is in different places on my 4X4 vs my 2X4
Old 04-07-2005, 03:57 PM   #7
402Bowtie
402Bowtie's Avatar
this is the reason I was asking:new 2wd gear box
Since I have a 4wd, it doesn't sound like I will be able to use it. They are $100+ new.
