04-06-2005, 03:58 PM | #1 |
Charging system info needed
HI All!
My charging sytem is not working right. 1972 Chevy C-10 350, auto I put new alt, voltage reg.(solid state) I check voltage at Terminal 2 and it is 12 volt and bat volt at battery connection is 12volt what should voltage at terminal @1 be on Alt??? any other ideas? Generator light stays on at idle, but when I rev it up it goes out???? Jeff Smith Pensacola, FL |
04-06-2005, 04:21 PM | #2 |
could be your battery? When the truck is running and you have a voltmeter on the right battery trminals, you should be pulling over 14 Volts at idle. If it's about half that, then your battery is screwed. I had this happen last fall on mine, ended up being a DUD battery. Usually when one part of your charging system starts to go, the rest will follow.
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
04-06-2005, 07:12 PM | #3 |
Charging System
I also put a new battery in and forgot to mention, thanks
I found a old post about it at: http://207.44.196.117/vboard/showthread.php3?t=119379 great info all around lots of great info, this board is better than the old military jeep board I use www.g503.com Jeff Smith Pensacola, FL mvpco@yahoo.com |
04-06-2005, 08:49 PM | #4 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Term 1 is the voltage sense line.
NO voltage should be present. This terminal tells the alt to start chargeing. It's take's a "sense" of the voltage being used by the electrical system and tells the alt to either produce more or less voltage via the internal voltage regulator.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
04-06-2005, 09:40 PM | #5 |
Check the fuses under the hood, along the fenders near the front. These are in black holders. They are used for the charging system. I think they are 5a and are used for the gauge circuit.
04-07-2005, 02:34 AM | #6 |
Those are for the Amp gauge only.
Even if both those fuses are blown the charging system will still work.
04-07-2005, 08:08 AM | #7 |
Charging System
I did it, no problems, WOW!
Great info Jeff Pensacola |
04-07-2005, 12:22 PM | #8 |
I mistakenly stated that term #1 "sense's" voltage.I'm sorry but that would be terminal #2.
Term. #1 only "turns on" the alt. and tells it to start charging.It also can operate the "ALT/charger" idiot light if don't have the gauge inst. cluster. Sorry for the misinformation.
