04-06-2005, 03:59 PM | #1 |
a/c compressor help
I have an 88 burb with dual air (front and rear) , i HAVE TO PUT IN A NEW A/C COMPRESSOR, going to r 134. How much of the special oil do I hve to add and where? How many lbs if r-134 do i install ?I already have the oil, r-134 etc.
72 c-10 81 c-30 67 c-10 just sittin in the woods) 70 C-10 " " " " to compleete frames 67, 70 - in woods 2002 toyota tundra. 12 yr old son has , 72 Charger, 78 Ramcharger and 85 ford wrecker |
05-09-2005, 01:21 PM | #2 |
I did my wifes 91 accord couple yearts back. Replaced the condensor and drier. It had a leak but the compressor was still ok.Compressor failure dumps alot crap into the system that garbage has to be flushed out.I bought a manifold gauge w/hoses leak about $80 a leak detector and cheap vacuum pump $50.Once the system is clean it is vacuumed out removing all moisture. Then the freon is suctioned back into the system.
It worked pretty good had a hard time gettin the freon to go back in but finally got it.This site has the tools. http://www.ackits.com/index.cfm?fuse...=black%20death I'm sure others with more experience will chime in. GO DAWGS!!! mike
68 Gmc 1/2 ton pickup 66 Malibu 87 GN 85 Sub parting out 03 Yukon |
