18 Till I Die
69 Big Block Towers
Anyone know why the holes in the towers are so large? and can you take out the 2 piece driveshaft and install a 1 piece. Does anyone make a conversion ?
![]() Last edited by kelsfine69; 04-06-2005 at 07:48 PM. |
The hole is large because the motor mount is 2 piece. The part that bolts to the block is similar to small block mount except it has a threaded hole right in the middle of it. There is a smaller mount that goes on the other side of the steel bracket & I believe it has a steel sleeve in it that passes through that big hole & up against the other half of mount. Then there is a large bolt that that bolts the whole works together sandwiching the steel frame bracket in between. I hope this is clear enough.
Rick-Ca. |
18 Till I Die
Can anyone send me a parts pic diagram? or where I can buy this inner mount and bolt
