04-07-2005, 06:22 AM | #1 |
Ford man with 65 GMC needs sage advice
Hi Folks...I'm in the process of buying a '65 I1502 (3/4 ton long bed, floor shift 4-speed) and I assumed that the orange small block V-8 (ramhorn manifolds, 2 BBL) was the original engine but it seems that this came with a straight six . I'm a veteran old car guy (Fords, Studebakers) and can usually spot any "butcher" work, but I'm not as yet familiar with these trucks. The installation must have been done years ago. The wavy round fan shroud looks factory, and everything seems to be all stock. Was this an easy "bolt-in" swap from a Chevy or were small blocks an option?
- The vehicles condition; looks like original paint, bed wood has rot, but you can stand up in it. Dings and dents. The drivers door is bent in the front edge because the little restraining bar broke at the pin. The door was opened too wide as a result, and the front fender edge did the creasing. Is this a common fault? - The dashboard instrument cluster has three round holes for gauges, but the far left one is just a gaping hole..what went there? - The truck has 8 lug split rims. Are there any common later solid rims that will accept the original GMC hubcaps? - The blue paint is worn off and there is plenty of surface rust, but the fender corners are solid ( I'm in Southern Califonia). There is a little stress cracking in the rear upper corners of the bed. I don't know the mechanical condition yet, it's sat for years. I plan on making it a clean work/tow vehicle. Is there anything else I need to look for? Thanks for any help! P.S. I've always thought the GMC "dog bone" grille looked great! |
04-07-2005, 12:55 PM | #2 |
Registered Smarta$$
wlecome another gmc guy lets see some pics. the door thing is common i think. 6066nut could help out more.
63 GMC custom going to be slammed Last edited by kamikazegmc; 04-07-2005 at 12:59 PM. |
04-07-2005, 01:13 PM | #3 |
Professional Beer Tester
1502, I'm not sure if the 60-66 GMC's were ever available with a small block or not, but regardless, swaping from the 230 or 250 six to a small block was pretty much a bolt in. Same mounts, bell housing, flywheel, etc. Swaping from the 292 was a little more difficult but still not that bad. The door checks were very common for breaking. I think the standard dash came with temp gauge, speedometer, and fuel gauge(L to R). Not sure what the other hole might have been for, but in forty years lots could have been changed too. As for the wheels, most any 8 hole wheel should fit the hubs, but I don't know if you'll find any to fit the old hub caps. You might find out more here:60-66 GMC Trucks Best of luck.
60-66 Nut
60 Ford F100 Custom Cab 61 Apache Short Fleetside 64 C10 Short Stepside 65 C80 409 V8 5spd(X-Firetruck) 83 GMC 350 Olds Diesel 85 GMC Short Bed 86 GMC Short Bed 90 GMC R3500 Crew Cab 92 GMC 1500 |
04-09-2005, 05:38 AM | #4 |
Thanks, guys. I'll try to post pictures soon.
I1502 |
