Old 04-07-2005, 11:02 AM   #1
Rod
Exclamation Speedometers with overspeed / tandem lock
Thought I'd post a pic of a speedometer with overspeed and tandem lock indicators. Where a light duty truck has a temp and brake indicator the larger trucks have these style gas gauges.
So this is what you have to change when building dash for someone or yourself. The red indicators are riveted onto the gas gauge backing plate so you can't just swap them out...you have to change to get rid of the tandem lock overspeed indicators. These gas gauges come in the bigger truck dashes C40 up stuff.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 04-07-2005, 12:40 PM   #2
ronh72c10
Looks just like the fuel gauge from the Tach dash I bought last year, it also had a different Bezel, where the steering column came through the opening dropped down a fair bit. I would have had to cut it out to use it but I just ended up buying a new bezel.
Ron
72 Chevy C10 (rust repaired, starting body work)
72 GMC 3/4ton 4x4
72 Chevy C20 Suburban
38 Ford Tudor Humpback Sedan (from the darkside)
67 Pontiac Parisienne
55 Studebaker Commander 2dr Hardtop (Starliner)
My Youtube channel with Video Updates!
ronh72c10 is offline   Reply With Quote
Old 04-07-2005, 12:59 PM   #3
junkyardjohn
junkyardjohn's Avatar
Yep-- Thats The Same Feul Gage That I Have In My Blazer. I Pulled A Tach/vac Out Of A C-50 & Didn't Change Anything But The Bezel. John
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 04-07-2005, 10:54 PM   #4
67-72williso
Junk/Daily Driver Club
67-72williso's Avatar
Cool speed warning
Rod, I used one of the overspeed lights in with my speed warning buzzer circuit.
Later Willis
Daily Driver: 1970 C-20 400 sbc,sm-465,Dana 61 one ton SRW rear, 3.07 gears, locker.
There are three kinds of people: those who make things happen, those who watch things happen, and those who have no idea what happened!
67-72williso is offline   Reply With Quote
Old 04-08-2005, 12:20 AM   #5
Rod
I was gonna toss it in the garbage unless someone wants it.
