More trusty Less rusty
Ignition removal help
I need to replace my ignition switch my first question is how do I remove it,I don't have the key but can turn it on with a screwdriver(I keep my title in the glove box beacause I can imagine what will happen if a police cruiser rolls up on me jaming a screwdriver in the ignition
![]() ![]() Last edited by rusted75 half ton; 04-07-2005 at 01:53 PM. |
Professional Grade
Yes, it is possible to put the wheel on crooked. Just mark the base of the wheel / top of the column before you pull the wheel, and don't rotate the shaft after that
![]() Keep an eye on where everything came, its not a difficult task, but there are a lot of little parts and peices that you can loose, or not put back in correctly ![]() ![]()
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
Insert Witty Text Here
http://home.t-online.de/home/O_Scholz/steering.html
I used this when I replaced my tumbler, turn signal switch, and lever. It is newer than yours, but it might be helpful. Slonaker Last edited by Slonaker; 04-07-2005 at 02:34 PM. |
Thanks for the response,mabey I'll take pics with a digital camera as I go
